Device version where the imei can be changed
According to the case of the imei change, there is a company that carries it out and it is not possible to compete with that company but we discovered that they change the imei’s to be able to occupy a residential SIM that is anchored to another device.
The devices that can be configured to change the IMEI are the following:
-RUTX11
-RUTX12
-TRB500
-RUT950
-RUT955
-RUT240
-RUT360
The firmware version used to change the IMEI is the following
00.07.02.4_WEBUI.bin
I hope you will support me in correcting this problem and forcing compliance with global standards since changing the IMEI is not legal in any country.
You are correct. Changing the IMEI is illegal in many countries and is already restricted on many devices. However, this issue will be addressed in upcoming firmware releases.
I wait at the time of updating to skip the IMEI change configuration and it no longer allows you to make the change in your new version of firmware.
I’m on the lookout.
