Good morning.
It’s a pity that the meaning of status words for profinet communication is not described anywhere. I had a problem with this but I managed to do it somehow. I copied the device status to the IW500. Bit I500.0 (bit 0) Bit I501.7 (bit 15)
I determined that
bit 0 - active port 8
bit 1-7 - I don’t know
bit 8 - I don’t know
bit 9 - active port 1
bit 10 - active port 2
bit 11 - active port 3
bit 12 - active port 4
bit 13 - active port 5
bit 14 - active port 6
bit 15 - active port 7
That’s a bit strange
The only “IW500” device I was able to find was an in-wall speaker, which doesn’t look to support Profinet.
Could you possibly clarify what device you had in mind and provide the documentation for it?
