If the device has an active internet connection and the RMS service is enabled, it should connect automatically, though it may take several minutes. If the device is still not connecting, I recommend checking for any errors in the WebUI by navigating to Services → Cloud Solutions → RMS, if you have remote access.
If you’re unable to access the WebUI, please let me know. I can then send you a form to contact you privately regarding some sensitive information about your devices so we can proceed further.
Hello, i have the same problem. After expire and activating new credits the modem TRB143 remains offline. But the connected devices are reachable. The WebUI button is not activ (grey). The Firmware version is “TRB1_R_00.07.09”
kind regards, Ludwig
Could you please confirm if you are still experiencing the same issue with the devices, or if all of them are now online and the issue has been resolved?
Hello, it was as follows:
Modem was initially switched off - subscription has since expired - modem switched on - new activation code entered - modem initially offline (no access to web UI possible, red dot next to model name) - only after 4 hours without any further action did the modem go back online. Now everything is working normally again.
Kind regards, Ludwig
Unfortunately, it is difficult to determine why it took 4 hours for the device to connect to RMS without a troubleshoot file. If you experience this issue again, please let us know on the forum so we can review the logs.
