Default route via IPSec VPN
Good day!
I’m running a Teltonika RUT241, OS version is RUT2M_R_00.07.11.3.
The setup: i establish a VPN IPSec IKEv1 tunnel with a default route, everything is working as expected, devices behind the Teltonika can reach the WWW via the router on the other side of the tunnel.
The issue: when the tunnel is down traffic is routed via WAN interface(a SIM card). I need to block traffic from leaving the WAN interface and use only the VPN default route. I have surfed the web and can’t find a similar case. All the rules i have tried either don’t work or block traffic both WAN and VPN.
Did anyone have a similar task/issue/experience?
I have tried a bunch of different rules or iptables.
These do nothing.
config rule '33'
        option name 'Allow-LAN-to-IPsec'
        option src 'lan'
        option dest 'wan'
        option extra '-m policy --dir out --pol ipsec'
        option proto 'all'
        option target 'ACCEPT'
        option priority '19'
config rule '34'
        option name 'Block-Direct-LAN-to-WAN'
        option src 'lan'
        option dest 'wan'
        option extra '-m policy --dir out --pol none'
        option proto 'all'
        option target 'DROP'
        option priority '20'
iptables -A FORWARD -s 192.168.0.0/24 -o qmimux0: -m policy --dir out --pol ipsec -j ACCEPT
iptables -A FORWARD -s 192.168.0.0/24 -o qmimux0: -m policy --dir out --pol none -j DROP
This blocks VPN and WAN.
config rule '34'
        option proto 'all'
        option name 'Block-Output'
        option priority '25'
        option extra '-m policy --pol none --dir out'
        option src 'lan'
        option dest 'wan'
Thank you in advance!
Good afternoon,
After looking and testing your query, i have a couple of notes.
As the IP sec instance creates on the same wan zone, the traffic block action needs to be trigered, when the session dissapears between server and client, therefore to achieve this, you would need to utilize a custom script.
It is possible to switch of masquerading, and forward everything via NAT, but you would lose internet connection then.
Arturas
