DDNS address not reachable
Hello everyone. I am trying in all ways to use DDNS but it does not work.
My router has IP address 192.168.1.1, I want to reach IP address 192.168.1.19 from outside on port 80
The DDNS service seems to work perfectly.
I did NAT ports from WAN to LAN on IP address 192.168.1.19 all protocols. Can you suggest me the exact procedure to follow.
Hi @bogomir,
you’re getting a private (i.e. not routable) IP address
from your provider. That’s not gonna work. Your provider
has to assign you a public IP - if you get a dynamic one
then you need DDNS indeed. If you get a static public
IP you don’t even need a DDNS service.
And (I think) you’d better use port forwarding instead of
SNAT.
Timelapse Admin (running 60+ routers with various port forwards and public IPs)
