Hello!
I Get this error in englich in my OpenVPN GUI in Windows:
dco connect error the semaphore timeout period has expired. Wed Oct 9 12:00:07 2024 dco connect error: Das Zeitlimit für die Semaphore wurde erreicht. (errno=121)
When i disable dco in the config i get litterally an “unnown” connection error…
I created once the keys in ubuntu with easy rsa and a econd time in Windows with easy rsa shell:
Its the first tie i had to create a .ovpn file manually. I had to change the cipher, because the default one is not compatiple with dco, but still get dco timeout
What i miss a little is a log where i can see if the vpn cient is connecting to the rut, i kknow at sophos i have to see the firewall traffic, but i dont know where i can see it in the RUT - i see something in connections, but my ip whith i trying to connect is not there.
The Wireguard VPN config+Connection was successfull.
Please check the logs on your Teltonika device, as they could help you determine the cause of the issue. You can do this on the WebUI by navigating to System → Maintenance → Troubleshoot and checking “System logs”.
Please let me know if you need any additional assistance with this.
Tue Oct 15 16:14:10 2024 MANAGEMENT: CMD 'echo on all'
Tue Oct 15 16:14:10 2024 MANAGEMENT: CMD 'bytecount 5'
Tue Oct 15 16:14:10 2024 MANAGEMENT: CMD 'state'
Tue Oct 15 16:14:10 2024 MANAGEMENT: CMD 'hold off'
Tue Oct 15 16:14:10 2024 MANAGEMENT: CMD 'hold release'
Tue Oct 15 16:14:10 2024 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Tue Oct 15 16:14:10 2024 TCP/UDP: Preserving recently used remote address: [AF_INET]62.112.81.213:1194
Tue Oct 15 16:14:10 2024 Socket Buffers: R=[65536->65536] S=[65536->65536]
Tue Oct 15 16:14:10 2024 Attempting to establish TCP connection with [AF_INET]62.112.81.213:1194
Tue Oct 15 16:14:10 2024 MANAGEMENT: >STATE:1729001650,TCP_CONNECT,,,,,,
Tue Oct 15 16:16:11 2024 TCP: connect to [AF_INET]62.112.81.213:1194 failed: Unknown error
Tue Oct 15 16:16:11 2024 SIGUSR1[connection failed(soft),connection-failed] received, process restarting
Tue Oct 15 16:16:11 2024 MANAGEMENT: >STATE:1729001771,RECONNECTING,connection-failed,,,,,
Tue Oct 15 16:16:11 2024 Restart pause, 1 second(s)
Tue Oct 15 16:16:12 2024 WARNING: No server certificate verification method has been enabled. See http://openvpn.net/howto.html#mitm for more info.
Tue Oct 15 16:16:12 2024 TCP/UDP: Preserving recently used remote address: [AF_INET]62.112.81.213:1194
Tue Oct 15 16:16:12 2024 Socket Buffers: R=[65536->65536] S=[65536->65536]
Tue Oct 15 16:16:12 2024 Attempting to establish TCP connection with [AF_INET]62.112.81.213:1194
Tue Oct 15 16:16:12 2024 MANAGEMENT: >STATE:1729001772,TCP_CONNECT,,,,,,
