Data to Server on Modbus stopped working
I have a working Modbus solution on a RUT956 with firmware 7.14.3 but was unable to upgrade due to a Modbus error described here
Link to issue
The topic was closed during my vacation, but is only partly fixed in version 7.16.3.
When I update it looks like Modbus is working but data is no longer sent to the MQTT broker using ‘Data to Server’ and it isn’t clear to me why not.
Best regards Peter
I have reopened the topic you are referring to. Kindly continue all communication regarding the Modbus issue within that ticket so we can keep the case organized and ensure a faster resolution.
Thank you!
Thanks, it looks like it works with test.mosquitto.org without credentials so I’ll test some more and update the original issue.
Regards Peter
