Data to server MQTT publishing period ignored
I’m using a RUT200 to publish MODBUS client data to a mqqt broker, altough Modbus TCP Client service acts as expected showing correct update requests on defined frequency, the Data to server service publishes a lot of messages per second no matter the period defined or the Qos selected.
Best regards
To better understand the issue, could you please clarify a couple of points?
  • What period is configured for the Modbus client’s requests?
  • What period is set for the Data to Server service that publishes messages to the MQTT broker?
Also, it would be very helpful if you could provide screenshots of the configuration windows for both the Modbus client and the Data to Server service.
Looking forward to your response.
