Data Connection Disconnected
Hi, I put a new sim card in my RUTX11 with a new MIMO-3-15 antenna and can’t connect to data mobile connection.
I see WAN and WAN6 are stoped
WAN and WAN6 are the physical IPv4/IPv6 WAN port (cabled).
You’re looking for mob1s1a1 which is the mobile connection.
Make sure it’s set to IPv4 only and double-check your APN settings.
Auto APN should work.
Oh, okqy, so I cant turn off the WAN and WAN6?
I configurate mob1s1a1 like you say and continues stopped
Before seen your comment I changed the WAN to mobile protocol and the sattus change to runnig, later i change all again hoy you say and stopped, and noting runs, later I change WAN to moble again and reboot the router and this is working.
Here you have a video of my config
Just leave WAN and WAN6 alone and as long as no cable is connected to WAN port, all is fine :wink:
So is it working now or not?
If not, easiest would be a quick factory reset I guess and you should be fine again in default config.
Just don’t play around wit WAN connections as this is absolutely not required.
