DAP140 Wireless bridge (client mode) signal drops
Currently, we are using a DAP140 as a Wi-Fi client. With the Relay configuration package, it bridges the Wi-Fi signal to the LAN port. A PLC is connected to this LAN port.
The goal is to connect a PLC to an existing Wi-Fi network. We have this setup working at the moment, but the connection frequently drops.
Do you have any advice on what we should check, or alternative methods to achieve a more stable solution?
Could you kindly confirm whether the issue has been resolved, or if you still require any assistance?
I will be happy to help if anything else is needed.
