I’m trying to make an end user role in RMS that are allowed to see the list of devices and the Device information page for each device. I’m nearly there but does anyone know which permission is needed so the “Ports” and “Network” tabs are visible?
Greetings JKJ,
Thank you for your question.
Could you please confirm whether you are referring to the “Ports” and “Network” tabs found in the device details section?
If so, all user roles should have access to the “Ports” tab. However, access to the “Network” tab is limited to Administrator and End User roles.
I hope this clarifies your query. Please let me know if you have any additional questions.
Warm regards,
Thank you Vilius.
I’m trying to create a stripped down end user role where you can only see the absolute minimum required.
I think I’ve nailed it down to the following permissions:
“View devices”
“View device remote access” (required for the Ports tab to be visible)
“Device API documentation” (both “view” and “apply” are needed to show the Network tab)
Greetings, JKJ,
Thank you for an update,
In case you have additional questions, please let us know!
