Custom Role configuration for VPN - Quick Connect Users
Use Case Description:
I would like to create a ‘specific user role’ for one of my teltonika rms user’s
With this rule the ‘specifc user role’ the user should just be able to invoke a VPN - connection through a preconfigured ‘VPN quick connect’ Item via pressing the ‘Start’ Button!
I tried it through the option assigning a specifc custom role to that user
In this Dialog one can configure the possible permissions for that specific user
In this context I do have the following specific question.: Which of the following permission are required on order to enable the user to invoke a VPN session trough pressing the ‘start’ button of the selected ‘VPN quick connect’ Item?
I tried the following permission simular to the settings I assigned the same user in order to enable him to make use (connect to) of preconfigured ‘Remote Access’ - Items!
If my requested Use Case for the role configuration is possible, can you provide me the correct settings?
Thank you
Christian
Good afternoon,
Currently, such separation of activities possible per role is not possible. We currently are working with our RMS RnD departament, to be able to separate that a user could only view VPN hubs or RMS quick connect, or start instances.
Unfortunately I do not have a timeframe for the implementation, keep an eye out for our newsletter.
Arturas
