Cumulocity lua script
Does anybody successfully run the cumulocity lua script
WikI 1st is wrong on current version luci.util and luci.sys doesn’t exist their are vuci. now
As wiki claim
Custom lua scripts can be placed in „/usr/local/usr/lib/lua/cm/“. Application will scan this folder for any *.lua files and load them if they contains „init“ function.
but simple 3 row script
function init()
os.execute(“echo inittest-script-init >> /tmp/cm_test.log”)
end
aproove that init() is never run
Any ideas?
Regards
Could you please provide the following details:
  • Device model
  • Firmware version currently in use
  • The Wiki article where the issue was noticed
This information will help with further investigation.
RUT200 RUT2M_R_00.07.19.4
Regards
Could you please confirm that the cumulocity package is installed in the router from the package manager? If not, you can navigate to System → Package manager to install it.
The /usr/local/usr/lib/lua/cm/ directory is created during package installation.
I look forward to your reply.
Cumulocity package is installed and router successfully connected to Cumulocity and send router telemetry to Cumulocity
/usr/local/usr/lib/lua/cm/ exist and has template file with content described in wiki
but when i create the lua script file with init() function, its doesn’t find it and init() is never executed
I tried the example from wiki and finaly simple script witch just write the message to file
To avoid the syntax error in script when i run script manually with explicity calling the init() function, the script is working
Regards
Juri
For troubleshooting purposes, we will require more sensitive information from your end, such as the troubleshoot file, which may contain passwords, public IP addresses, serial numbers, and such. To avoid leaking this information, we have sent you a form to fill out, which you will receive in your e-mail inbox that you have registered your account with in the forums. In the Ticket ID field of the form, please enter the ID of this thread, which is 18079.
