I am sending GPS data in NMEA format via HTTPS for a RUTX50. I am only interested in the RMC sentence and reduced logging to every 10 minutes.
The interval setting for HTTPS seems to only reduce the frequency with which logs are sent to the server however there is still underlying data for every second and all NMEA messages are sent. Previously I have been given advice to use the section but this only works if NMEA forwarding using TCP/UDP.
How do I control the frequency of logging and NMEA messages when forwarding using HTTPS?
Marty
