We are using a TRB255, we are trying to setup the serial port to communicate with some third party equipment over RS232.
When connecting our PCs to the serial port of TRB255 there’s a lot of garbage being written to the serial port, it doesn’t make sense on any speed or encoding that we’ve tried.
Is there any configuration on the TRB255 that enables this?
Some extract of the content. (extracted with jpnevulator --ascii --timing-print --tty /dev/ttyUSB0 --read)
38 78 00 3C 78 78 78 78 78 78 7C 38 78 38 38 78 8x.<xxxxxx|8x88x
3C 78 78 00 78 38 78 78 78 F8 78 7C 1C 38 78 38 <xx.x8xxx.x|.8x8
78 78 70 78 78 78 38 78 78 78 78 F8 78 38 78 78 xxpxxx8xxxx.x8xx
3C 78 78 70 00 38 78 78 38 F8 78 3C 3C 78 78 78 <xxp.8xx8.x<<xxx
78 78 70 78 78 78 78 78 38 70 78 F8 38 78 3C 78 xxpxxxxx8px.8x<x
78 38 78 70 78 78 78 78 78 38 F8 F8 38 38 78 38 x8xpxxxxx8..88x8
78 78 38 70 00 38 78 78 78 78 78 3C 78 38 38 78 xx8p.8xxxxx<x88x
78 78 78 70 00 00 38 78 78 78 78 78 3C 78 3C 78 xxxp..8xxxxx<x<x
78 38 7C 78 78 00 00 78 78 78 38 78 F8 F8 38 78 x8|xx..xxx8x..8x
78 78 78 38 70 F0 78 38 78 78 78 78 78 78 F8 78 xxx8p.x8xxxxxx.x
38 78 78 38 70 78 30 00 00 78 78 78 78 78 78 78 8xx8px0..xxxxxxx
3C 78 78 78 70 78 78 00 78 78 38 78 78 3C 78 F8 <xxxpxx.xx8xx<x.
78 38 78 78 78 78 38 70 38 78 78 78 38 78 78 3C x8xxxx8p8xxx8xx<
F8 38 38 78 78 3C 78 78 70 38 78 78 3C 78 78 3C .88xx<xxp8xx<xx<
F8 F8 3C 78 78 38 78 78 78 70 00 78 38 78 78 78 ..<xx8xxxp.x8xxx
78 78 78 78 38 78 78 78 78 78 78 00 78 3C 78 78 xxxx8xxxxxx.x<xx
78 78 78 3C 78 38 78 78 38 78 78 00 7C 78 78 78 xxx<x8xx8xx.|xxx
38 78 78 F8 1C 78 78 38 78 78 78 78 38 3C 38 78 8xx..xx8xxxx8<8x
78 3C 78 78 7C 78 78 78 78 38 78 78 00 3C 78 78 x<xx|xxxx8xx.<xx
78 78 78 3C 00 78 78 38 70 78 78 78 78 F8 00 78 xxx<.xx8pxxxx..x
38 78 78 38 78 78 7C 1C 78 78 38 78 78 38 00 78 8xx8xx|.xx8xx8.x
78 38 78 78 78 F8 F8 3C 38 78 78 38 78 78 70 00 x8xxx..<8xx8xxp.
78 3C 78 78 38 78 F8 78 78 78 38 78 78 38 70 00 x<xx8x.xxx8xx8p.
78 78 78 78 78 78 78 78 78 38 78 78 78 70 78 00 xxxxxxxxx8xxxpx.
00 78 3C 78 78 78 78 78 7C 78 78 78 3C 78 78 38 .x<xxxxx|xxx<xx8
70 70 78 38 78 78 78 F8 1E 7C F8 38 78 38 38 78 ppx8xxx..|.8x88x
78 78 78 78 78 78 78 78 78 3C FC 78 70 78 78 78 xxxxxxxxx<.xpxxx
78 38 00 38 38 78 38 78 78 3C 78 F8 38 38 78 78 x8.88x8xx<x.88xx
78 78 78 00 00 38 78 78 78 78 78 38 F8 3C 70 78 xxx..8xxxxx8.<px
38 78 78 38 00 00 38 78 78 3C F8 78 3C F8 38 78 8xx8..8xx<.x<.8x
78 78 78 78 78 00 78 3C 78 78 78 78 78 3C 38 78 xxxxx.x<xxxxx<8x
78 38 F8 78 70 78 00 00 38 78 78 78 78 78 F8 78 x8.xpx..8xxxxx.x
38 78 78 78 78 78 78 00 00 78 78 38 78 78 78 78 8xxxxxx..xx8xxxx
78 78 7C 38 78 78 38 78 78 38 78 78 78 78 78 78 xx|8xx8xx8xxxxxx
78 00 38 78 78 78 78 78 78 78 38 78 78 3C 7C 78 x.8xxxxxxx8xx<|x
F8 78 78 78 78 38 78 78 78 38 78 78 78 38 78 38 .xxxx8xxx8xxx8x8
Regards
