Helo Guys i need help with setup RUT901 and rms .
For network A i have acces only on cabel with mac adress . I caonnected cabel from network A to RUT901 port wan and i override mac adres . How setup RMS to got acces to network A ???
Best Regards
Best Regards
To access remotely what you have on your RUT901 WAN port, you can create a VPN hub. Detailed instructions can be found here. Please remember to enable WAN in routes next to your router.
Let me know if you have any further questions regarding this.
Hei thx for answer , I made Hub and turned on wan switch in routes client . After 2-3 min Rms hub is dead
Could you please clarify what you mean? Has it disconnected?
Please ensure that you haven’t disabled or closed the OpenVPN app.
I mean after 2-3 min is disconnected … Openvpn app is open hub is on . On website is info rut901 is offline
I would like to review the troubleshoot file. I have sent you a form to fill out. Once completed, I will contact you privately. Please use “6950” for the ticket ID.
where u sended me that form ? because i don’t got anything ![]()
I have sent the form to the email you have registered with on this forum. Please check your spam folder. I have sent the form one more time.
Hei
yestarday i fillout form , do you know when somebody can help me . I have to fix asap that problem if not i have to turn back teltonika and buy something different .
Best regards
You should receive an email shortly regarding your issue. Thank you for your patience!
