Connecting Starlink Mini via WIFI/Multi AP to RUT950
I recently got a Starlink Mini. The Starlink MIni shoulb be flexible used at home and on travel within my RV. I would like to operate the Starlink in my RV with a power connection only and not connect it to the RUT950 via an Ethernet cable. (One cable is enough). In short words: Using Starlink as a hotspot for RUT950.
I want to connect via WIFI from the RUT950 to the integrated Starlink router via Multi-AP. Multi AP is already set up to other public and private WIFI hotspots. Is this possible and what needs to be considered/set up?
Hi Dr.Pillepalle,
If Starlink will provide connectivity to RUT950 via Wi-Fi, RUT950 should be configured as Wi-Fi Client, more information HERE. Please note that this device only supports 2.4 GHz Wi-Fi Band. Once configured, end devices can connect to RUT950’s Wi-Fi interface.
Let me know if this helps.
Janmiguel,
I just changed the WIFI Network from Mutli-AP to Client, and everything works perfekt. Thank you.
