Hello, to all.
It´s possible to add to RUT 260 one fan using the 4 pin / input & output.
If possible, one scheme please.
Hello, to all.
Depending on the amount of power the fan needs, it may be possible. According to the datasheet of the RUT260 - the 1 x Digital Output has a max output of 30 V, 300 mA, more information in the Input / Output section under “All features”: RUT260 Cat 6 Wi-Fi Router
If you’re interested in the pinout of the 4-pin block, you can find it here: RUT260 Powering Options - Teltonika Networks Wiki
