Hi
I use the Serial over IP function on the RUT956 modem. I need to transmit the message arriving from the RS-232 port to 4 servers.
For the server filters accept the messages from the RUT956, I need to activate the “Connect on Data” function, but in this case I can’t add more than one IP address to the addresses in client mode.Is this normal? Can it be bypassed or modified? Can this be corrected? If I don’t activate this function, the Rut956 doesn’t send a message to initiate the connection, but only the message with the data, which is problematic.
Thank’s
