Connect LAN by mobile on two RUT901
I have two RUT901 with mobil connection.
Both have a LAN 10.0.48.0.
I want device A (10.0.48.94) on RUT1 to be able to talk to device B device A (10.0.48.95) on RUT2 over port 753.
What is the easiest way to do this?
Both are connected to RMS.
If there is not physical connection between the two devices and you’d like for them to communicate, then your best shot would be using a VPN. If you are using RMS as you mention, you can create a new VPN Hub and add both of these devices to it as clients. For setting up the VPN Hubs, we have a Wiki guide available here: RMS VPN Hubs - Teltonika Networks Wiki
If you could clarify exactly what kind of set up you have (whether they are connected physically or not) that would help us to understand better.
