Configuration template
Hello!
Can I create a configuration template from an already manually configured device?
We use RUT901.
Or what is the best way to setup 20 of this? All settings are some, only the IP of router changes and the wireGuard settings.
Thank you!
When you mention “Configuration template” - do you mean to say that you are also using RMS, or do you want to do this from the device itself?
If it’s the latter, then you can utilize Backups: RUT901 Maintenance - Teltonika Networks Wiki
An important thing to note, is that Backups can only be uploaded on devices with the same exact product code (found under Status → System), as for the firmwares, it is recommended to also have all the firmware versions match, to avoid any conflicts/unexpected errors.
Hi Mantas,
Thank you for your answer.
We can use RMS if needed.
We want to make configuration template based on an already (manually) configured router.
So then we can deploy to other routers.
Thanks!
Regards
In that case, you need to utilize the Device configuration functionality on RMS:
Then, depending on what you have set up, for this example, we’ll take it that we only changed the LAN interface settings:
We’ll press the “Get configurations from device” button to retrieve the current configurations of our interfaces:
Then, we’ll select the LAN interface and press on “Apply configuration”, and we will be able to see the changes on the right-hand side:
You can then click on the “save current configuration” button to save it as a template:
And in the future, you can then just click on the “Templates” button to view your saved templates, and you can then apply them:
Dear Matas!
Thank you very much!
Regards!
