I try to compile the firmware for the RUT955. The reason is that I need support for the USB Wifi adapter RT5370, which not part of the kernel.
To build the firmware, I followed the process as explained here.
Building rsa_pkey_tool utility…^[[0m
rsa_pkey_tool.c: In function ‘int write_bignum_to_header(FILE*, const char*, BIGNUM*, int)’:
rsa_pkey_tool.c:87:2: error: ‘uint32_t’ was not declared in this scope
uint32_t *buf, *ptr;
rsa_pkey_tool.c:87:2: note: suggested alternative: ‘u_int32_t’
It seems that rsa_pkey_tool utility does not compile well.
How I solve this, such that I can build the firmware?
Is there any news? I literally followed the instructions on Teltonika’s website but while compiling a new image (without any changes) there are errors. Teltonika still every now and then releases new images for the RUT955, so they should be able to build those images. I want to do the same.
I completely understand your concern. At the moment, I am still waiting for feedback from our developers. I have already asked them when we can expect an update regarding your question, and as soon as I receive any information, I will share it with you right away.
We truly appreciate your patience and understanding.
