Command in cli of modbus tcp master
He,
I use a RUT956 with the firmware 00.07.03.3. The RUT956 should be a Modbus master device. I want to get the Modbus master values from the Modbus slave device. I like to write a small script by using CLI. Therefore, I need a command and options to get the value of the TCP master . Is there a solution offer. is there a manual for editing the modbus registry via cli?
Best regards
Michal
I assume this post is a duplicate. I have provided Modbus commands in your other post here. Please, if you have any questions or issues, share those in your other post.
