Close-proximity Airport Dual Deployment
Hi All,
I have a conundrum that I have been advised to post to here:
I have 2 x RUT241 routers deployed in close proximity, both broadcasting 3 x SSIDs that are identical. Currently the SSIDs are set to Access Point mode.
The issue I have is if I were to configure these routers to work in a Mesh Network, then one router would be the Mesh Node and the other the Mesh Gateway.
However as each router has one SIM we are worried about usage limits and so is there a way to occassionally change the Mesh Node router to the Mesh Gateway and vice versa to utilise both data limits?
On a side note, I assume the devices would connect to the router providing the strongest signal but would there be an issue with stability if both routers were broadcasting on the same channel for example.
I appreciate that there would be easier solutions by replacing routers etc but this is what I’m facing with no route for replacement currently.
Many thanks for your thoughts
Greetings, @WHopkins ,
Since your setup involves a more complex configuration, I’ve forwarded your case to our IoT engineering team for a deeper review. Any updates or the final solution will be provided to you directly through the Helpdesk platform.
Best wishes,
Hi Vilius,
I don’t believe I have access to a helpdesk platform. Can I ask any updates or resolution to be sent directly to me email?
Many thanks,
W.
Access was granted and you should be able to see the progress in the HelpDesk platform.
Warm regards,
