CLI Command Library / List / Reference
Is there a library, list or reference of commands relative to CLI and respective devices? Asking as CLI commands that worked pre 00.07.08 no longer work with 00.07.08 for basically the same function.
You can find basic information here: Teltonika Networks Shell Commands.
Additionally, command files are located in the same directories as other Linux systems, such as:
  • /bin
  • /sbin
  • /usr/bin
  • /usr/sbin
  • /etc
Could you identify which CLI commands do not work with version 07.08?
You can actually use API through CLI with /sbin/api to have an easy access to every function that WebUI does. All API methods are shown in documentation page.
Was the changes to NTRIP (RUT956 / RUTX50) that took a few days to get the new commands such as rs_ntrip stop & start, ntrip_client -s -D etc. In general was thinking, well what other command files might be of interest?
@pwsh Wow thanks for the link to that API reference. :pray: I didn’t know this was possible and it opens up a lot of possibilities!
