Changing IPSEC settings via ssh RUT240/241
Hello everyone.
I have problem with changing ipsec vpn settings on RUT240 via ssh.
I try to change files
/etc/ipsec.conf
/etc/ipsec.secrets
/tmp/ipsec/ipsec.conf
/tmp/ipsec/ipsec.secrets
Then i restart ipsec /etc/init.d/ipsec restart
After that, the settings return to the old ones.
The configuration file is /etc/config/ipsec.
Change it and restart ipsec you should have the correct settings in /tmp/ipsec/*
On RUT950002XXX Firmware RUT9_R_00.07.04.3 i have /etc/config/ipsec file. Thanx
But I no have this file on Firmware RUT2XX_R_00.01.14
Hi…
Why you don’t upgrade it, using this URL?
https://wiki.teltonika-networks.com/view/RUT240_Firmware_Downloads_(legacy_WebUI)
Do you have an old hardware?
RUT240 devices with MeigLink SLM750 module are only supported on firmware version RUT2XX_R_00.01.14.4 and up.
I find file /etc/config/strongswan on RUT240
and i change ipsec settings on it.
Thanx for help.
