Change I/O relay status according to schedule
Is it possible to configure the operation of I/O RELAY according to the schedule?
For example, the status of the RELAY should change every day at 14:00 and after 30 seconds the status should change to the previous state.
Thanks in advance.
Yes, it is possible to schedule the output of the relay according to a specific period. This can be done using the Scheduler feature, which can be found in the router’s WebUI by navigating to Services → Input/Output → Scheduler. You will need to create 7 output scheduler instances, as shown in the screenshot below.
Please note that the shortest period between the start and end time is 1 minute, so a 30-second interval is not supported. Additionally, make sure to enable the Scheduler service for it to function properly.
I hope this helps! Let me know if you have any additional questions or need further assistance.
