Hello everyone. I’m looking for a router with support for 5G and Wi-Fi, which I can use for my application for customers all over the world.
I came across the RUTX50 and RUTM50 (a version for North America and one for Japan). A lot of ground is covered by them, although none of these have a certification for China (I believe SRRC or NAL certification is required). Some support the 5G frequencies in China, but I assume certification is still required. Is this correct?
Do you have equipment which is certified for use in China?
Yes, you are correct. Without these certifications, even if a device supports the appropriate 5G frequencies, it may not legally operate in China, nor will it be able to connect to official telecom. Also, you might find it difficult to import such products to the country.
