Hi Caner,
Thanks for checking it.
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.000000] Linux version 5.4.259 (app@runner-ju9hssqs-project-352-concurrent-2) (gcc version 8.4.0 (OpenWrt GCC 8.4.0 r16279-5cc0535800)) #0 Thu Aug 8 07:41:57 2024
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] printk: bootconsole [early0] enabled
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] CPU0 revision is: 0001974c (MIPS 74Kc)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] MIPS: machine is Teltonika RUT9XX
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] SoC: Atheros AR9344 rev 3
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] Initrd not found or empty - disabling initrd
Thu Aug 8 07:50:00 2024 kern.warn kernel: [ 0.000000] Primary instruction cache 64kB, VIPT, 4-way, linesize 32 bytes.
Thu Aug 8 07:50:00 2024 kern.warn kernel: [ 0.000000] Primary data cache 32kB, 4-way, VIPT, cache aliases, linesize 32 bytes
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] Zone ranges:
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] Normal [mem 0x0000000000000000-0x0000000007ffffff]
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] Movable zone start for each node
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] Early memory node ranges
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] node 0: [mem 0x0000000000000000-0x0000000007ffffff]
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x0000000007ffffff]
Thu Aug 8 07:50:00 2024 kern.debug kernel: [ 0.000000] On node 0 totalpages: 32768
Thu Aug 8 07:50:00 2024 kern.debug kernel: [ 0.000000] Normal zone: 256 pages used for memmap
Thu Aug 8 07:50:00 2024 kern.debug kernel: [ 0.000000] Normal zone: 0 pages reserved
Thu Aug 8 07:50:00 2024 kern.debug kernel: [ 0.000000] Normal zone: 32768 pages, LIFO batch:7
Thu Aug 8 07:50:00 2024 kern.debug kernel: [ 0.000000] pcpu-alloc: s0 r0 d32768 u32768 alloc=132768
Thu Aug 8 07:50:00 2024 kern.debug kernel: [ 0.000000] pcpu-alloc: [0] 0
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 32512
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.000000] Kernel command line: console=ttyS0,115200 rootfstype=squashfs,jffs2
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] Dentry cache hash table entries: 16384 (order: 4, 65536 bytes, linear)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] Inode-cache hash table entries: 8192 (order: 3, 32768 bytes, linear)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] Writing ErrCtl register=00000000
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] Readback ErrCtl register=00000000
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] Memory: 123592K/131072K available (4046K kernel code, 164K rwdata, 620K rodata, 1240K init, 187K bss, 7480K reserved, 0K cma-reserved)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] SLUB: HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] NR_IRQS: 51
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] CPU clock: 550.000 MHz
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000000] clocksource: MIPS: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 6950037990 ns
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.000011] sched_clock: 32 bits at 275MHz, resolution 3ns, wraps every 7809031678ns
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.008788] Calibrating delay loop… 273.66 BogoMIPS (lpj=547328)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.055668] pid_max: default: 32768 minimum: 301
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.060978] Mount-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.069145] Mountpoint-cache hash table entries: 1024 (order: 0, 4096 bytes, linear)
Thu Aug 8 07:50:00 2024 kern.warn kernel: [ 0.080230] Duplicate name in mnfinfo, renamed to “name#1”
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.090900] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.101812] futex hash table entries: 256 (order: -1, 3072 bytes, linear)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.109469] pinctrl core: initialized pinctrl subsystem
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.117202] NET: Registered protocol family 16
Thu Aug 8 07:50:00 2024 kern.warn kernel: [ 0.158036] gpio-17 (i2c@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
Thu Aug 8 07:50:00 2024 kern.warn kernel: [ 0.168246] gpio-16 (i2c@0): enforced open drain please flag it properly in DT/ACPI DSDT/board file
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.178849] i2c-gpio i2c@0: using lines 17 (SDA) and 16 (SCL)
Thu Aug 8 07:50:00 2024 kern.warn kernel: [ 0.185684] workqueue: max_active 576 requested for napi_workq is out of range, clamping between 1 and 512
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.201995] clocksource: Switched to clocksource MIPS
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.209088] NET: Registered protocol family 2
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.214339] IP idents hash table entries: 2048 (order: 2, 16384 bytes, linear)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.223490] tcp_listen_portaddr_hash hash table entries: 512 (order: 0, 4096 bytes, linear)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.232929] TCP established hash table entries: 1024 (order: 0, 4096 bytes, linear)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.241507] TCP bind hash table entries: 1024 (order: 0, 4096 bytes, linear)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.249393] TCP: Hash tables configured (established 1024 bind 1024)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.256653] UDP hash table entries: 256 (order: 0, 4096 bytes, linear)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.264008] UDP-Lite hash table entries: 256 (order: 0, 4096 bytes, linear)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.272148] NET: Registered protocol family 1
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.277091] PCI: CLS 0 bytes, default 32
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.286778] workingset: timestamp_bits=30 max_order=15 bucket_order=0
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.301202] squashfs: version 4.0 (2009/01/31) Phillip Lougher
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.307764] squashfs: patched 4.0 (2020/11/10) Oever Gonzalez
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.314185] jffs2: version 2.2 (NAND) (SUMMARY) (LZMA) (RTIME) (CMODE_PRIORITY) (c) 2001-2006 Red Hat, Inc.
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.344486] pinctrl-single 1804002c.pinmux: 544 pins, size 68
Thu Aug 8 07:50:00 2024 kern.err kernel: [ 0.357701] spi spi0.1: INFO: gpio[3] set up status(0)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.364503] shift_io@0 enforce active low on chipselect handle
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.377062] spi-nor spi0.0: xt25f128b (16384 Kbytes)
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.382729] 5 fixed-partitions partitions found on MTD device spi0.0
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.389824] Creating 5 MTD partitions on “spi0.0”:
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.395202] 0x000000000000-0x000000020000 : “u-boot”
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.401906] 0x000000020000-0x000000030000 : “config”
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.408636] 0x000000030000-0x000000040000 : “art”
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.415084] 0x000000040000-0x000000f70000 : “firmware”
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.427082] 2 tplink-fw partitions found on MTD device firmware
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.433745] Creating 2 MTD partitions on “firmware”:
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.439315] 0x000000000000-0x00000018e98c : “kernel”
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.446079] 0x00000018e98c-0x000000f30000 : “rootfs”
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.452714] mtd: device 5 (rootfs) set to be root filesystem
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.461574] 1 squashfs-split partitions found on MTD device rootfs
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.468553] 0x000000c20000-0x000000f30000 : “rootfs_data”
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 0.475729] 0x000000f70000-0x000001000000 : “event-log”
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.486847] MNFINFO PROPERTIES:
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.490418] mac : XXXXXXXXXXXX
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.494415] name : RUT955M03XXX
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.498406] serial : XXXXXXXXXXXX
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.502198] hwver : XXXX
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.505396] batch : XXXX
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.508615] sim_count: 2
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.511535] blver : 3.2.6
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.515239] Serial: 8250/16550 driver, 1 ports, IRQ sharing disabled
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.523357] printk: console [ttyS0] disabled
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.528259] 18020000.uart: ttyS0 at MMIO 0x18020000 (irq = 9, base_baud = 2500000) is a 16550A
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.537912] printk: console [ttyS0] enabled
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.546826] printk: bootconsole [early0] disabled
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.560568] ar933x-uart 18500000.uart: Incompatible hardware, disabling RS485 RTS control!
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 0.569169] 18500000.uart: ttyATH1 at MMIO 0x18500000 (irq = 12, base_baud = 2500000) is a AR933X UART
Thu Aug 8 07:50:00 2024 kern.err kernel: [ 0.923111] ag71xx 19000000.eth: Could not connect to PHY device. Deferring probe.
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 1.572185] switch0: Atheros AR8229 rev. 1 switch registered on mdio.0
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 1.616017] ag71xx 1a000000.eth: connected to PHY at fixed-0:00 [uid=00000000, driver=Generic PHY]
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 1.626096] eth0: Atheros AG71xx at 0xba000000, irq 5, mode: gmii
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 1.632610] i2c /dev entries driver
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 1.646808] NET: Registered protocol family 10
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 1.657497] Segment Routing with IPv6
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 1.661477] NET: Registered protocol family 17
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 1.666477] 8021q: 802.1Q VLAN Support v1.8
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 1.673243] gpio-export gpio-export: 5 gpio(s) exported
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 1.995962] ag71xx 19000000.eth: connected to PHY at mdio.0:1f:04 [uid=004dd042, driver=Generic PHY]
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 2.006628] eth1: Atheros AG71xx at 0xb9000000, irq 4, mode: mii
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 2.020393] VFS: Mounted root (squashfs filesystem) readonly on device 31:5.
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 2.035180] Freeing unused kernel memory: 1240K
Thu Aug 8 07:50:00 2024 kern.warn kernel: [ 2.039821] This architecture does not have kernel memory protection.
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 2.046366] Run /sbin/init as init process
Thu Aug 8 07:50:00 2024 user.info kernel: [ 2.682894] init: Console is alive
Thu Aug 8 07:50:00 2024 user.info kernel: [ 2.687006] init: - watchdog -
Thu Aug 8 07:50:00 2024 user.info kernel: [ 5.343419] kmodloader: loading kernel modules from /etc/modules-boot.d/
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 5.534260] usbcore: registered new interface driver usbfs
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 5.539984] usbcore: registered new interface driver hub
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 5.545530] usbcore: registered new device driver usb
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 5.713392] ehci_hcd: USB 2.0 ‘Enhanced’ Host Controller (EHCI) Driver
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 5.731630] SCSI subsystem initialized
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 5.745434] fsl-ehci: Freescale EHCI Host controller driver
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 5.754674] ehci-platform: EHCI generic platform driver
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 5.760379] ehci-platform 1b000000.usb: EHCI Host Controller
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 5.766249] ehci-platform 1b000000.usb: new USB bus registered, assigned bus number 1
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 5.774334] ehci-platform 1b000000.usb: irq 3, io mem 0x1b000000
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 5.794017] ehci-platform 1b000000.usb: USB 2.0 started, EHCI 1.00
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 5.801540] hub 1-0:1.0: USB hub found
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 5.805937] hub 1-0:1.0: 1 port detected
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 5.835623] usbcore: registered new interface driver usb-storage
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 6.066043] usb 1-1: new high-speed USB device number 2 using ehci-platform
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 6.236889] hub 1-1:1.0: USB hub found
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 6.243162] hub 1-1:1.0: 4 ports detected
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 6.542029] usb 1-1.3: new full-speed USB device number 3 using ehci-platform
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 8.874110] mmc_spi spi0.1: SD/MMC host mmc0, no WP, no poweroff, cd polling
Thu Aug 8 07:50:00 2024 user.info kernel: [ 8.883908] kmodloader: done loading kernel modules from /etc/modules-boot.d/*
Thu Aug 8 07:50:00 2024 kern.warn kernel: [ 8.891508] mmc_spi spi0.1: no card detected
Thu Aug 8 07:50:00 2024 kern.err kernel: [ 8.895878] mmc0: error -22 whilst initialising SD card
Thu Aug 8 07:50:00 2024 user.info kernel: [ 8.911754] init: - preinit -
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 9.608716] Executing do_sysinfo_generic preinit_main …
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 9.708578] Executing preinit_config_board preinit_main …
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 11.442908] random: jshn: uninitialized urandom read (4 bytes read)
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 11.568070] random: jshn: uninitialized urandom read (4 bytes read)
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 11.864680] Executing do_mount_root preinit_main …
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 11.870052] Mounting root…
Thu Aug 8 07:50:00 2024 user.notice kernel: [ 11.917588] mount_root: Searching for rootfs_data…
Thu Aug 8 07:50:00 2024 user.notice kernel: [ 11.926499] mount_root: Mounting exroot…
Thu Aug 8 07:50:00 2024 user.info kernel: [ 11.932173] mount_root: loading kmods from internal overlay
Thu Aug 8 07:50:00 2024 user.info kernel: [ 12.071591] kmodloader: loading kernel modules from //etc/modules-boot.d/*
Thu Aug 8 07:50:00 2024 user.info kernel: [ 12.086290] kmodloader: done loading kernel modules from //etc/modules-boot.d/*
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 12.906321] jffs2: notice: (648) jffs2_build_xattr_subsystem: complete building xattr subsystem, 33 of xdatum (28 unchecked, 4 orphan) and 50 of xref (4 dead, 4 orphan) found.
Thu Aug 8 07:50:00 2024 user.info kernel: [ 12.923097] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
Thu Aug 8 07:50:00 2024 user.info kernel: [ 12.942447] block: extroot: not configured
Thu Aug 8 07:50:00 2024 user.notice kernel: [ 12.949164] mount_root: Initializing rootfs_data…
Thu Aug 8 07:50:00 2024 user.notice kernel: [ 12.954705] mount_root: Detecting type of rootfs_data…
Thu Aug 8 07:50:00 2024 user.notice kernel: [ 12.960687] mount_root: Overlay detected in rootfs_data, mounting…
Thu Aug 8 07:50:00 2024 user.notice kernel: [ 12.967569] mount_root: Preparing overlay to mount…
Thu Aug 8 07:50:00 2024 user.notice kernel: [ 12.973159] mount_root: Searching for mount point…
Thu Aug 8 07:50:00 2024 user.notice kernel: [ 12.979257] mount_root: Mounting overlay filesystem…
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 13.080356] jffs2: notice: (646) jffs2_build_xattr_subsystem: complete building xattr subsystem, 33 of xdatum (28 unchecked, 4 orphan) and 50 of xref (4 dead, 4 orphan) found.
Thu Aug 8 07:50:00 2024 user.notice kernel: [ 13.097071] mount_root: Mounting exroot filesystem…
Thu Aug 8 07:50:00 2024 user.info kernel: [ 13.637483] block: attempting to load /tmp/jffs_cfg/upper/etc/config/fstab
Thu Aug 8 07:50:00 2024 user.info kernel: [ 13.654289] block: extroot: not configured
Thu Aug 8 07:50:00 2024 user.notice kernel: [ 13.660592] mount_root: OVERLAYFS: Ready
Thu Aug 8 07:50:00 2024 user.notice kernel: [ 13.665111] mount_root: OVERLAYFS: sync
Thu Aug 8 07:50:00 2024 user.info kernel: [ 13.669591] mount_root: switching to jffs2 overlay
Thu Aug 8 07:50:00 2024 kern.warn kernel: [ 13.679851] overlayfs: upper fs does not support tmpfile.
Thu Aug 8 07:50:00 2024 user.notice kernel: [ 13.687837] mount_root: OVERLAYFS: done
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 13.693103] Restoring hotplug.d subsystem…
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 13.700848] Preparing mount_root hook…
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 13.706647] Executing do_urandom_seed preinit_main …
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 13.713179] urandom-seed: Seeding with /etc/urandom.seed
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 13.791065] Executing do_power_modem preinit_main …
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 13.855038] random: mctl: uninitialized urandom read (4 bytes read)
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 15.189554] Executing prepare_evtlog preinit_main …
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 15.195001] - preparing events-log partition -
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 15.301553] Unlocking /dev/mtd7 …
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 15.395671] jffs2: notice: (661) jffs2_build_xattr_subsystem: complete building xattr subsystem, 0 of xdatum (0 unchecked, 0 orphan) and 0 of xref (0 dead, 0 orphan) found.
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 15.413712] Executing set_passwords preinit_main …
Thu Aug 8 07:50:00 2024 user.info kernel: [ 15.484946] procd: - early -
Thu Aug 8 07:50:00 2024 user.info kernel: [ 15.488363] procd: - watchdog -
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 16.106561] [01-serial-symlink.sh] New device ttyS0 at /devices/platform/ahb/ahb:apb/18020000.uart/tty/ttyS0 appeared!
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 16.144181] random: jsonfilter: uninitialized urandom read (4 bytes read)
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 16.167619] random: jsonfilter: uninitialized urandom read (4 bytes read)
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 16.189458] random: jsonfilter: uninitialized urandom read (4 bytes read)
Thu Aug 8 07:50:00 2024 user.info kernel: [ 16.196691] procd: - watchdog -
Thu Aug 8 07:50:00 2024 user.info kernel: [ 16.202230] procd: - ubus -
Thu Aug 8 07:50:00 2024 user.info kernel: [ 16.372005] procd: - init -
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 16.543422] [01-serial-symlink.sh] New device ttyATH1 at /devices/platform/ahb/ahb:apb/18500000.uart/tty/ttyATH1 appeared!
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 16.798608] [01-serial-symlink.sh] Creating /dev/ttyATH1 → /dev/rs485 symlink…
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 18.143884] random: jshn: uninitialized urandom read (4 bytes read)
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 18.181575] random: ubusd: uninitialized urandom read (4 bytes read)
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 18.188500] random: ubus: uninitialized urandom read (4 bytes read)
Thu Aug 8 07:50:00 2024 user.info kernel: [ 19.151722] urngd: v1.0.2 started.
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 19.453150] random: jsonfilter: uninitialized urandom read (4 bytes read)
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 19.512756] random: crng init done
Thu Aug 8 07:50:00 2024 kern.notice kernel: [ 19.516270] random: 37 urandom warning(s) missed due to ratelimiting
Thu Aug 8 07:50:00 2024 user.info kernel: [ 20.322576] kmodloader: loading kernel modules from /etc/modules.d/*
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 20.533620] ntfs: driver 2.1.32 [Flags: R/O MODULE].
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 20.560767] NET: Registered protocol family 15
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 20.572581] Initializing XFRM netlink socket
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 20.582849] tun: Universal TUN/TAP device driver, 1.6
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 20.673597] l2tp_core: L2TP core driver, V2.0
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 20.688550] l2tp_netlink: L2TP netlink interface
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 20.705582] sit: IPv6, IPv4 and MPLS over IPv4 tunneling driver
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 20.729268] l2tp_eth: L2TP ethernet pseudowire support (L2TPv3)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 20.768224] l2tp_ip: L2TP IP encapsulation support (L2TPv3)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 20.794750] l2tp_ip6: L2TP IP encapsulation support for IPv6 (L2TPv3)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 20.805570] gre: GRE over IPv4 demultiplexor driver
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 20.831022] ip_gre: GRE over IPv4 tunneling driver
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 20.869829] ip6_gre: GRE over IPv6 tunneling driver
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.172475] tlt-gpio: set names for 18040000.gpio chip
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.179007] tlt-gpio: set names for 74hc595 chip
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.188974] GACT probability on
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.196158] Mirror/redirect action on
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.243621] u32 classifier
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.246446] input device check on
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.250189] Actions configured
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.356198] fuse: init (API version 7.31)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.385590] usbcore: registered new interface driver usbserial_generic
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.392392] usbserial: USB Serial support registered for generic
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.428566] usbcore: registered new interface driver cypress_reconf
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.435116] usbcore: registered new interface driver cypress_serial
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.441617] usbserial: USB Serial support registered for CY7C65213
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.448013] cypress_serial 1-1.3:1.0: CY7C65213 converter detected
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.490815] usb 1-1.3: CY7C65213 converter now attached to ttyUSB0
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.548593] usbcore: registered new interface driver ark3116
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.554534] usbserial: USB Serial support registered for ark3116
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.583575] usbcore: registered new interface driver belkin_sa
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.589688] usbserial: USB Serial support registered for Belkin / Peracom / GoHubs USB Serial Adapter
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.678541] usbcore: registered new interface driver cdc_acm
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.684346] cdc_acm: USB Abstract Control Model driver for USB modems and ISDN adapters
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.737364] usbcore: registered new interface driver cdc_wdm
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.772063] usbcore: registered new interface driver ch341
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.777814] usbserial: USB Serial support registered for ch341-uart
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.835307] usbcore: registered new interface driver usb_ch343
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.841286] ch343: USB serial driver for ch342/ch343/ch344/ch347/ch9101/ch9102/ch9103/ch9104, etc.
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.850391] ch343: V1.5 On 2022.12
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.908006] Loading modules backported from Linux version v5.10.68-0-g4d8524048a35
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.915757] Backport generated by backports.git v5.10.68-1-0-ga4f9ba32
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.936111] usbcore: registered new interface driver cp210x
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.941955] usbserial: USB Serial support registered for cp210x
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.982530] usbcore: registered new interface driver cypress_m8
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.988736] usbserial: USB Serial support registered for DeLorme Earthmate USB
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 21.996220] usbserial: USB Serial support registered for HID->COM RS232 Adapter
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 22.003790] usbserial: USB Serial support registered for Nokia CA-42 V2 Adapter
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 22.117126] usbcore: registered new interface driver ftdi_sio
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 22.123158] usbserial: USB Serial support registered for FTDI USB Serial Device
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 22.261814] mcp3021 0-004d: Found ADC: MCP3021
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 22.474576] usbcore: registered new interface driver pl2303
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 22.480428] usbserial: USB Serial support registered for pl2303
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 22.570539] usbcore: registered new interface driver usblp
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 22.699621] xt_time: kernel timezone is -0000
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 23.709632] usbcore: registered new interface driver option
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 23.715495] usbserial: USB Serial support registered for GSM modem (1-port)
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 23.754119] PPP generic driver version 2.4.2
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 23.767585] PPP MPPE Compression module registered
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 23.781142] NET: Registered protocol family 24
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 23.796243] PPTP driver version 0.8.5
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 23.822775] usbcore: registered new interface driver qmi_wwan
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 23.878722] wireguard: WireGuard 1.0.0 loaded. See www.wireguard.com for information.
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 23.886735] wireguard: Copyright (C) 2015-2019 Jason A. Donenfeld Jason@zx2c4.com. All Rights Reserved.
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 24.250377] l2tp_ppp: PPPoL2TP kernel driver, V2.0
Thu Aug 8 07:50:00 2024 kern.debug kernel: [ 24.334618] ath: EEPROM regdomain sanitized
Thu Aug 8 07:50:00 2024 kern.debug kernel: [ 24.334632] ath: EEPROM regdomain: 0x64
Thu Aug 8 07:50:00 2024 kern.debug kernel: [ 24.334638] ath: EEPROM indicates we should expect a direct regpair map
Thu Aug 8 07:50:00 2024 kern.debug kernel: [ 24.334665] ath: Country alpha2 being used: 00
Thu Aug 8 07:50:00 2024 kern.debug kernel: [ 24.334670] ath: Regpair used: 0x64
Thu Aug 8 07:50:00 2024 kern.debug kernel: [ 24.348537] ieee80211 phy0: Selected rate control algorithm ‘minstrel_ht’
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 24.351343] ieee80211 phy0: Atheros AR9340 Rev:3 mem=0xb8100000, irq=13
Thu Aug 8 07:50:00 2024 user.info kernel: [ 24.390981] kmodloader: done loading kernel modules from /etc/modules.d/*
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 24.544430] [01-serial-symlink.sh] New device ttyUSB0 at /devices/platform/ahb/1b000000.usb/usb1/1-1/1-1.3/1-1.3:1.0/ttyUSB0/tty/ttyUSB0 appeared!
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 24.730057] [01-serial-symlink.sh] Creating /dev/ttyUSB0 → /dev/rs232 symlink…
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 26.486260] usb 1-1.4: new high-speed USB device number 4 using ehci-platform
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 26.623031] option 1-1.4:1.0: GSM modem (1-port) converter detected
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 26.629847] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB1
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 26.638155] option 1-1.4:1.1: GSM modem (1-port) converter detected
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 26.644950] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB2
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 26.653243] option 1-1.4:1.2: GSM modem (1-port) converter detected
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 26.660044] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB3
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 26.668379] option 1-1.4:1.3: GSM modem (1-port) converter detected
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 26.675199] usb 1-1.4: GSM modem (1-port) converter now attached to ttyUSB4
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 26.921390] qmi_wwan 1-1.4:1.4: cdc-wdm0: USB WDM device
Thu Aug 8 07:50:00 2024 kern.info kernel: [ 26.943570] qmi_wwan 1-1.4:1.4 wwan0: register ‘qmi_wwan’ at usb-1b000000.usb-1.4, WWAN/QMI device, 16:69:69:e3:16:2a
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 27.647495] [01-serial-symlink.sh] New device ttyUSB1 at /devices/platform/ahb/1b000000.usb/usb1/1-1/1-1.4/1-1.4:1.0/ttyUSB1/tty/ttyUSB1 appeared!
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 28.579266] [01-serial-symlink.sh] New device ttyUSB2 at /devices/platform/ahb/1b000000.usb/usb1/1-1/1-1.4/1-1.4:1.1/ttyUSB2/tty/ttyUSB2 appeared!
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 29.517001] [01-serial-symlink.sh] New device ttyUSB3 at /devices/platform/ahb/1b000000.usb/usb1/1-1/1-1.4/1-1.4:1.2/ttyUSB3/tty/ttyUSB3 appeared!
Thu Aug 8 07:50:00 2024 user.warn kernel: [ 30.671709] [01-serial-symlink.sh] New device ttyUSB4 at /devices/platform/ahb/1b000000.usb/usb1/1-1/1-1.4/1-1.4:1.3/ttyUSB4/tty/ttyUSB4 appeared!
Thu Aug 8 07:50:04 2024 user.notice : Added device handler type: bonding
Thu Aug 8 07:50:04 2024 user.notice : Added device handler type: 8021ad
Thu Aug 8 07:50:04 2024 user.notice : Added device handler type: 8021q
Thu Aug 8 07:50:04 2024 user.notice : Added device handler type: macvlan
Thu Aug 8 07:50:04 2024 user.notice : Added device handler type: veth
Thu Aug 8 07:50:04 2024 user.notice : Added device handler type: bridge
Thu Aug 8 07:50:04 2024 user.notice : Added device handler type: Network device
Thu Aug 8 07:50:04 2024 user.notice : Added device handler type: tunnel
Thu Aug 8 07:50:06 2024 user.notice dnsmasq: DNS rebinding protection is active, will discard upstream RFC1918 responses!
Thu Aug 8 07:50:06 2024 user.notice dnsmasq: Allowing 127.0.0.0/8 responses
Thu Aug 8 07:50:08 2024 daemon.info dnsmasq[2168]: started, version 2.89 cachesize 150
Thu Aug 8 07:50:08 2024 daemon.info dnsmasq[2168]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Thu Aug 8 07:50:08 2024 daemon.info dnsmasq[2168]: UBus support enabled: connected to system bus
Thu Aug 8 07:50:08 2024 daemon.info dnsmasq[2168]: using only locally-known addresses for test
Thu Aug 8 07:50:08 2024 daemon.info dnsmasq[2168]: using only locally-known addresses for onion
Thu Aug 8 07:50:08 2024 daemon.info dnsmasq[2168]: using only locally-known addresses for localhost
Thu Aug 8 07:50:08 2024 daemon.info dnsmasq[2168]: using only locally-known addresses for invalid
Thu Aug 8 07:50:08 2024 daemon.info dnsmasq[2168]: using only locally-known addresses for bind
Thu Aug 8 07:50:08 2024 daemon.info dnsmasq[2168]: using only locally-known addresses for lan
Thu Aug 8 07:50:08 2024 daemon.warn dnsmasq[2168]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Thu Aug 8 07:50:08 2024 daemon.info dnsmasq[2168]: read /etc/hosts - 12 names
Thu Aug 8 07:50:08 2024 daemon.info dnsmasq[2168]: read /tmp/hosts/dhcp.cfg01411c - 0 names
Thu Aug 8 07:50:13 2024 daemon.notice wpa_supplicant[2222]: Successfully initialized wpa_supplicant
Thu Aug 8 07:50:14 2024 daemon.info gsmd[2341]: gsmd-ng init
Thu Aug 8 07:50:14 2024 daemon.info gsmd[2341]: gsmd-ng canary build git#8d8281018c1
Thu Aug 8 07:50:14 2024 daemon.info gsmd[2341]: AT traffic support: yes
Thu Aug 8 07:50:14 2024 daemon.info gsmd[2341]: Baseband feature support: no
Thu Aug 8 07:50:14 2024 daemon.info gsmd[2341]: gsmd-ng running
Thu Aug 8 07:50:17 2024 daemon.notice procd: /etc/rc.d/S13openssl: Generating engines.cnf
Thu Aug 8 07:50:17 2024 daemon.notice procd: /etc/rc.d/S13openssl: Generating providers.cnf
Thu Aug 8 07:50:17 2024 daemon.err mobifd: Failed to get information about modems
Thu Aug 8 07:50:17 2024 daemon.notice procd: /etc/rc.d/S13openssl: Enabling legacy
Thu Aug 8 07:50:19 2024 daemon.info gsmd[2341]: [ubus_notify_event:299] error: [MODEM_UBUS] Failed to send ubus notify for 1-1.4 [2c7c:0125] modem!
Thu Aug 8 07:50:20 2024 daemon.info mobifd: [gsm.modem0] Starting modem settings init
Thu Aug 8 07:50:20 2024 daemon.info mobifd: [gsm.modem0] SIM is ready
Thu Aug 8 07:50:20 2024 daemon.err mobifd: [gsm.modem0] GSM error in “generic_enable_urc_cause:638” (Failed to parse response), gsmd_method_id: “163”
Thu Aug 8 07:50:22 2024 daemon.info mobifd: [gsm.modem0] Modem settings init completed
Thu Aug 8 07:50:22 2024 daemon.info mobifd: [gsm.modem0] Starting connection setup
Thu Aug 8 07:50:23 2024 daemon.err mobifd: [gsm.modem0] GSM error in “mb_manage_volte:229” (Failed to parse response), gsmd_method_id: “95”
Thu Aug 8 07:50:23 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “15s” of timeout
Thu Aug 8 07:50:26 2024 authpriv.info dropbear[2710]: Not backgrounding
Thu Aug 8 07:50:33 2024 kern.info kernel: [ 65.616913] eth0: link up (1000Mbps/Full duplex)
Thu Aug 8 07:50:33 2024 kern.info kernel: [ 65.634217] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
Thu Aug 8 07:50:33 2024 kern.info kernel: [ 65.648473] br-lan: port 1(eth0.1) entered blocking state
Thu Aug 8 07:50:33 2024 kern.info kernel: [ 65.654194] br-lan: port 1(eth0.1) entered disabled state
Thu Aug 8 07:50:33 2024 kern.info kernel: [ 65.660134] device eth0.1 entered promiscuous mode
Thu Aug 8 07:50:33 2024 kern.info kernel: [ 65.665053] device eth0 entered promiscuous mode
Thu Aug 8 07:50:33 2024 kern.info kernel: [ 65.724681] br-lan: port 1(eth0.1) entered blocking state
Thu Aug 8 07:50:33 2024 kern.info kernel: [ 65.730258] br-lan: port 1(eth0.1) entered forwarding state
Thu Aug 8 07:50:33 2024 daemon.notice netifd: Interface ‘lan’ is enabled
Thu Aug 8 07:50:33 2024 daemon.notice netifd: Interface ‘lan’ is setting up now
Thu Aug 8 07:50:33 2024 daemon.notice netifd: Interface ‘lan’ is now up
Thu Aug 8 07:50:33 2024 daemon.notice netifd: bridge ‘br-lan’ link is up
Thu Aug 8 07:50:33 2024 daemon.notice netifd: Interface ‘lan’ has link connectivity
Thu Aug 8 07:50:33 2024 daemon.notice netifd: Interface ‘loopback’ is enabled
Thu Aug 8 07:50:33 2024 daemon.notice netifd: Interface ‘loopback’ is setting up now
Thu Aug 8 07:50:33 2024 daemon.notice netifd: Interface ‘loopback’ is now up
Thu Aug 8 07:50:33 2024 daemon.notice netifd: Interface ‘wan’ is enabled
Thu Aug 8 07:50:33 2024 daemon.notice netifd: Interface ‘wan6’ is enabled
Thu Aug 8 07:50:33 2024 daemon.notice netifd: bridge ‘br-lan’ link is down
Thu Aug 8 07:50:33 2024 daemon.notice netifd: Interface ‘lan’ has link connectivity loss
Thu Aug 8 07:50:33 2024 daemon.notice netifd: Network device ‘eth0’ link is up
Thu Aug 8 07:50:33 2024 daemon.notice netifd: VLAN ‘eth0.1’ link is up
Thu Aug 8 07:50:33 2024 daemon.notice netifd: Network device ‘lo’ link is up
Thu Aug 8 07:50:33 2024 daemon.notice netifd: Interface ‘loopback’ has link connectivity
Thu Aug 8 07:50:34 2024 kern.info kernel: [ 66.630784] IPv6: ADDRCONF(NETDEV_CHANGE): br-lan: link becomes ready
Thu Aug 8 07:50:35 2024 daemon.notice netifd: radio0 (2924): WARNING: Variable ‘data’ does not exist or is not an array/object
Thu Aug 8 07:50:36 2024 user.notice firewall: Reloading firewall due to ifup of lan (br-lan)
Thu Aug 8 07:50:37 2024 kern.notice Port link state of port CPU/WiFi changed to UP
Thu Aug 8 07:50:37 2024 kern.notice Port speed for port CPU/WiFi changed to 1000 baseT
Thu Aug 8 07:50:37 2024 kern.notice Port link state of port LAN3 changed to UP
Thu Aug 8 07:50:37 2024 kern.notice Port speed for port LAN3 changed to 100 baseT
Thu Aug 8 07:50:37 2024 kern.notice Port link state of port LAN2 changed to UP
Thu Aug 8 07:50:37 2024 kern.notice Port speed for port LAN2 changed to 100 baseT
Thu Aug 8 07:50:37 2024 kern.notice Port link state of port LAN1 changed to UP
Thu Aug 8 07:50:37 2024 kern.notice Port speed for port LAN1 changed to 100 baseT
Thu Aug 8 07:50:43 2024 kern.debug kernel: [ 75.528058] ath: EEPROM regdomain: 0x8348
Thu Aug 8 07:50:43 2024 kern.debug kernel: [ 75.528068] ath: EEPROM indicates we should expect a country code
Thu Aug 8 07:50:43 2024 kern.debug kernel: [ 75.528078] ath: doing EEPROM country->regdmn map search
Thu Aug 8 07:50:43 2024 kern.debug kernel: [ 75.528086] ath: country maps to regdmn code: 0x3a
Thu Aug 8 07:50:43 2024 kern.debug kernel: [ 75.528094] ath: Country alpha2 being used: US
Thu Aug 8 07:50:43 2024 kern.debug kernel: [ 75.528099] ath: Regpair used: 0x3a
Thu Aug 8 07:50:43 2024 kern.debug kernel: [ 75.528107] ath: regdomain 0x8348 dynamically updated by user
Thu Aug 8 07:50:43 2024 kern.notice ip_blockd service is enabled, initialized firewall rules
Thu Aug 8 07:50:44 2024 daemon.notice hostapd: Set new config for phy phy0:
Thu Aug 8 07:50:44 2024 daemon.notice wpa_supplicant[2222]: Set new config for phy phy0
Thu Aug 8 07:50:46 2024 cron.err crond[3475]: crond (busybox 1.34.1) started, log level 5
Thu Aug 8 07:50:47 2024 daemon.notice wpa_supplicant[2222]: Set new config for phy phy0
Thu Aug 8 07:50:47 2024 daemon.notice hostapd: Set new config for phy phy0: /var/run/hostapd-phy0.conf
Thu Aug 8 07:50:47 2024 daemon.notice hostapd: Restart interface for phy phy0
Thu Aug 8 07:50:49 2024 daemon.info dnsmasq[2168]: exiting on receipt of SIGTERM
Thu Aug 8 07:50:49 2024 daemon.info dnsmasq[3620]: started, version 2.89 cachesize 150
Thu Aug 8 07:50:49 2024 daemon.info dnsmasq[3620]: compile time options: IPv6 GNU-getopt no-DBus UBus no-i18n no-regex no-IDN DHCP no-DHCPv6 no-Lua TFTP no-conntrack no-ipset no-nftset no-auth no-cryptohash no-DNSSEC no-ID loop-detect inotify dumpfile
Thu Aug 8 07:50:49 2024 daemon.info dnsmasq[3620]: UBus support enabled: connected to system bus
Thu Aug 8 07:50:49 2024 daemon.info dnsmasq-dhcp[3620]: DHCP, IP range 192.168.1.100 – 192.168.1.249, lease time 12h
Thu Aug 8 07:50:49 2024 daemon.info dnsmasq[3620]: using only locally-known addresses for test
Thu Aug 8 07:50:49 2024 daemon.info dnsmasq[3620]: using only locally-known addresses for onion
Thu Aug 8 07:50:49 2024 daemon.info dnsmasq[3620]: using only locally-known addresses for localhost
Thu Aug 8 07:50:49 2024 daemon.info dnsmasq[3620]: using only locally-known addresses for invalid
Thu Aug 8 07:50:49 2024 daemon.info dnsmasq[3620]: using only locally-known addresses for bind
Thu Aug 8 07:50:49 2024 daemon.info dnsmasq[3620]: using only locally-known addresses for lan
Thu Aug 8 07:50:49 2024 daemon.warn dnsmasq[3620]: no servers found in /tmp/resolv.conf.d/resolv.conf.auto, will retry
Thu Aug 8 07:50:49 2024 daemon.info dnsmasq[3620]: read /etc/hosts - 12 names
Thu Aug 8 07:50:49 2024 daemon.info dnsmasq[3620]: read /tmp/hosts/dhcp.cfg01411c - 2 names
Thu Aug 8 07:50:49 2024 daemon.info dnsmasq-dhcp[3620]: read /etc/ethers - 0 addresses
Thu Aug 8 07:50:50 2024 daemon.notice hostapd: Configuration file: data: driver=nl80211 logger_syslog=127 logger_syslog_level=2 logger_stdout=127 logger_stdout_level=2 country_code=US ieee80211d=1 hw_mode=g supported_rates=60 90 120 180 240 360 480 540 basic_rates=60 120 240 beacon_int=100 dtim_period=2 #num_global_macaddr=1 ieee80211n=1 ht_coex=0 ht_capab=[LDPC][SHORT-GI-20][SHORT-GI-40][TX-STBC][RX-STBC1][DSSS_CCK-40] channel=acs_survey interface=wlan0 bssid=00:1e:42:2e:25:88 ctrl_interface=/var/run/hostapd ap_isolate=1 bss_load_update_period=60 chan_util_avg_period=600 disassoc_low_ack=1 skip_inactivity_poll=0 preamble=1 wmm_enabled=1 ignore_broadcast_ssid=0 uapsd_advertisement_enabled=1 utf8_ssid=1 multi_ap=0 wpa_passphrase=c6Z7Gux1 wpa_psk_file=/etc/hostapd/wlan0.psk auth_algs=1 wpa=2 wpa_pairwise=CCMP ssid=RUT955_2588 bridge=br-lan wpa_disable_eapol_key_retries=0 wpa_key_mgmt=WPA-PSK okc=0 disable_pmksa_caching=1 dynamic_vlan=0 vlan_naming=1 vlan_file=/var/run/hostapd-wlan0.vlan config_id=3c62650c31aa8e0f6f5e7bc08efd87
Thu Aug 8 07:50:50 2024 kern.info kernel: [ 82.900155] br-lan: port 2(wlan0) entered blocking state
Thu Aug 8 07:50:50 2024 kern.info kernel: [ 82.905624] br-lan: port 2(wlan0) entered disabled state
Thu Aug 8 07:50:50 2024 kern.info kernel: [ 82.911481] device wlan0 entered promiscuous mode
Thu Aug 8 07:50:50 2024 daemon.notice hostapd: wlan0: interface state UNINITIALIZED->COUNTRY_UPDATE
Thu Aug 8 07:50:50 2024 daemon.notice hostapd: ACS: Automatic channel selection started, this may take a bit
Thu Aug 8 07:50:50 2024 daemon.notice hostapd: wlan0: interface state COUNTRY_UPDATE->ACS
Thu Aug 8 07:50:50 2024 daemon.notice hostapd: wlan0: ACS-STARTED
Thu Aug 8 07:50:51 2024 daemon.notice netifd: Wireless device ‘radio0’ is now up
Thu Aug 8 07:50:53 2024 daemon.info mobifd: [gsm.modem0] APN “” isn’t prepared for PDP “1”, preparing it
Thu Aug 8 07:50:53 2024 cron.err crond[3836]: crond (busybox 1.34.1) started, log level 5
Thu Aug 8 07:50:56 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “15s” of timeout
Thu Aug 8 07:50:56 2024 daemon.notice hostapd: wlan0: ACS-COMPLETED freq=2457 channel=10
Thu Aug 8 07:50:57 2024 kern.info kernel: [ 90.151803] IPv6: ADDRCONF(NETDEV_CHANGE): wlan0: link becomes ready
Thu Aug 8 07:50:57 2024 kern.info kernel: [ 90.158582] br-lan: port 2(wlan0) entered blocking state
Thu Aug 8 07:50:57 2024 kern.info kernel: [ 90.164043] br-lan: port 2(wlan0) entered forwarding state
Thu Aug 8 07:50:57 2024 daemon.notice netifd: Network device ‘wlan0’ link is up
Thu Aug 8 07:50:57 2024 daemon.notice hostapd: wlan0: interface state ACS->ENABLED
Thu Aug 8 07:50:57 2024 daemon.notice hostapd: wlan0: AP-ENABLED
Thu Aug 8 07:51:03 2024 daemon.notice procd: /etc/rc.d/S96ledman: setting up led LAN1
Thu Aug 8 07:51:03 2024 daemon.notice procd: /etc/rc.d/S96ledman: setting up led LAN2
Thu Aug 8 07:51:03 2024 daemon.notice procd: /etc/rc.d/S96ledman: setting up led LAN3
Thu Aug 8 07:51:03 2024 daemon.notice procd: /etc/rc.d/S96ledman: setting up led WAN
Thu Aug 8 07:51:04 2024 cron.err crond[4425]: crond (busybox 1.34.1) started, log level 5
Thu Aug 8 07:51:07 2024 daemon.info dnsmasq-dhcp[3620]: DHCPDISCOVER(br-lan) XX:XX:XX:XX:XX
Thu Aug 8 07:51:07 2024 daemon.info dnsmasq-dhcp[3620]: DHCPOFFER(br-lan) 192.168.1.212 XX:XX:XX:XX:XX
Thu Aug 8 07:51:07 2024 daemon.info dnsmasq-dhcp[3620]: DHCPREQUEST(br-lan) 192.168.1.212 XX:XX:XX:XX:XX
Thu Aug 8 07:51:07 2024 daemon.info dnsmasq-dhcp[3620]: DHCPACK(br-lan) 192.168.1.212 XX:XX:XX:XX:XX raspberrypi
Thu Aug 8 07:51:08 2024 kern.info Leased 192.168.1.212 IP address for client XX:XX:XX:XX:XX - raspberrypi in LAN
Thu Aug 8 07:51:26 2024 daemon.info procd: - init complete -
Thu Aug 8 07:51:26 2024 daemon.info mobifd: [gsm.modem0] APN “telstra.internet” isn’t prepared for PDP “1”, preparing it
Thu Aug 8 07:51:26 2024 daemon.info dfota[4745]: Searching for WAN…
Thu Aug 8 07:51:30 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “15s” of timeout
Thu Aug 8 07:52:00 2024 daemon.info mobifd: [gsm.modem0] APN “telstra.wap” isn’t prepared for PDP “1”, preparing it
Thu Aug 8 07:52:03 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “30s” of timeout
Thu Aug 8 07:53:03 2024 daemon.info mobifd: [gsm.modem0] APN “” isn’t prepared for PDP “1”, preparing it
Thu Aug 8 07:53:07 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “30s” of timeout
Thu Aug 8 07:54:07 2024 daemon.info mobifd: [gsm.modem0] APN “telstra.internet” isn’t prepared for PDP “1”, preparing it
Thu Aug 8 07:54:10 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “30s” of timeout
Thu Aug 8 07:55:10 2024 daemon.info mobifd: [gsm.modem0] APN “telstra.wap” isn’t prepared for PDP “1”, preparing it
Thu Aug 8 07:55:13 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “60s” of timeout
Thu Aug 8 07:57:14 2024 daemon.info mobifd: [gsm.modem0] APN “” isn’t prepared for PDP “1”, preparing it
Thu Aug 8 07:57:17 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “60s” of timeout
Thu Aug 8 07:59:17 2024 daemon.info mobifd: [gsm.modem0] APN “telstra.internet” isn’t prepared for PDP “1”, preparing it
Thu Aug 8 07:59:21 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “60s” of timeout
Thu Aug 8 08:01:21 2024 daemon.info mobifd: [gsm.modem0] APN “telstra.wap” isn’t prepared for PDP “1”, preparing it
Thu Aug 8 08:01:24 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “180s” of timeout
Thu Aug 8 08:07:25 2024 daemon.info mobifd: [gsm.modem0] APN “” isn’t prepared for PDP “1”, preparing it
Thu Aug 8 08:07:28 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “180s” of timeout
Thu Aug 8 08:12:53 2024 kern.notice Port link state of port LAN2 changed to DOWN
Thu Aug 8 08:13:28 2024 daemon.info mobifd: [gsm.modem0] APN “telstra.internet” isn’t prepared for PDP “1”, preparing it
Thu Aug 8 08:13:32 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “180s” of timeout
Thu Aug 8 08:19:32 2024 daemon.info mobifd: [gsm.modem0] APN “telstra.wap” isn’t prepared for PDP “1”, preparing it
Thu Aug 8 08:19:35 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “300s” of timeout
Thu Aug 8 08:29:36 2024 daemon.info mobifd: [gsm.modem0] APN “” isn’t prepared for PDP “1”, preparing it
Thu Aug 8 08:29:39 2024 daemon.info mobifd: [gsm.modem0] Attempting to establish connection to operator with “300s” of timeout
Thu Aug 8 08:31:31 2024 authpriv.info dropbear[8668]: Child connection from 192.168.1.200:43329
Thu Aug 8 08:31:36 2024 authpriv.notice dropbear[8668]: Password auth succeeded for ‘root’ from 192.168.1.200:43329
Thu Aug 8 08:31:36 2024 kern.notice Password auth succeeded for root on SSH from 192.168.1.200:43329
