I have an existing UniFi network in my home-based office. The UniFi UDM-SE can support multiple internet inputs (WAN ports), and as I am hosting business-critical infrastructure, I want to have a 4G connection as a backup internet connection. I don’t need any help with the UniFi side of things.
I bought a TRB140 and tried to follow the quick start guide today.
I set a custom IP address for the TRB140 to 192.168.1.69 as that space is reserved in the UniFi network specifically for this.
At this stage, I don’t have the TRB140 even plugged into the UniFi network. I simply have the SIM card inside the TRB140, and have it connected directly to my Apple iMac computer so I could set the TRB140 up.
I went through the wizard and at the end of it, I just got a blank page with an error message intermittently appearing saying it couldn’t connect to the modem.
Assuming this was because it had just applied the new IP address (192.168.1.69), I navigated there instead using my web browser, but nothing loads at all. I just get an unreachable error. And the iMac computer can’t access the internet at all, despite the coverage indicator being full and the 4G light being illuminated on the TRB140.
I guess I’ve done something incorrect here… in any case, I’ve pressed the reset button and am now able to get back the web UI via 192.168.2.1.
I then tried again, but this time I clicked the “skip wizard” button at the start, so the system is using default settings, I guess(?). Despite this, my iMac still can’t access the internet, even with what should be a very easy setup with default settings.
If I go into the System > Maintenance > Troubleshooting page, I am able to ping google [dot] com with no lost packets, so presumably the internet connection is working…?
(I had to type google [dot] com because your forum doesn’t allow more than two links in a post for new users)
I would like to attach the troubleshoot file, but your forum doesn’t allow new users to do so, which seems shortsighted. In any case, I have uploaded it to my Dropbox account, accessible [here]
The mobile connection status page shows the mobile connection is connected…
This is with a brand new Telstra (Australia) SIM card which has been activated so shouldn’t be having problems.
I have been able to update the firmware to TRB1_R_00.07.07.3 from the server rather than uploading a file, so that suggests to me that the TRB140 has internet access…
Could someone please explain how I should set things up?
Thank you.
