Can't login to default IP
Hi. Sorry if this topic already exists. I can’t access the default IP 192.168.1.1.
Does anyone have this same problem? Thanks.
Hi…
This is device was working and just stop to allow to login?
What ip address you got at lan of your pc/mac (dhcp)?
It’s not possible to enter the web UI at all. When I enter the default IP the page doesn’t load at all. It used to be working well.
Do you have a backup of your device?
Can you try a factory reset of your device.
Hello @rvlig ,
Please let me know if performing a factory reset resolved the issue, or if you still require further assistance.
Hello Marija. Do you think it has something to do with the router (RUTC50)? When I enter the default IP in my browser (Safari) and press enter, a login screen should appear but that doesn’t happen. Only message I get is that the server doesn’t respond. When I try to access the web UI I’m not close to the router but that’s not necessary I think.
The default IP address 192.168.1.1 is a private IP, which allows you to access the router through a LAN network. You can connect your RUTC50 to your PC via an Ethernet cable or connect your PC to the router’s WiFi. This way, your PC will be in the same network as the RUTC50 and can access it using the default IP.
For remote access, please refer to the following wiki page: Remote Device Access.
Also, please check the Quick Start Guide for your device here: Quick Start Guide RUTC50.
Please let me know if you need further assistance.
Sorry for my stupidity. Thanks Marija and Marcelo.Barros for your help.
There are no stupid questions! We’re always happy to help.
Please don’t hesitate to reach out on the forum if you have any further questions or need assistance.
