Continuing an automatically closed topic here… I am unable to connect to a device through my RUT956, and I can’t connect to the router’s web interface through its VPN IP address. Copying Marija’s latest response:
Please ensure that in your router’s WebUI, under System → Administration → Access Control, the “WebUI” remote HTTP access is enabled. If it is turned off, you will not be able to reach your device remotely.
I don’t see anything like that on the remote management system. Do I have to be physically connected to the router to see System>Administration, etc.? Or how do I get to the location you’re describing?
Thanks,
Clayton
