I’ve got a RUTX08 that I cannot log in to even though I’ve factory reset it multiple times, and also reset to bootloader and upgraded firmware a couple of times.
It’s currently on 7.6.10 which is the latest as I write this.
This is a batch 21 device that still used admin/admin00. Could there be a problem where newer firmware requires a login using the password on the sticker? (There’s ofc no password on this sticker).
Our default passwords are admin/admin01
And can you please give me a bit more information regarding the situation?
Did you successfully finish the bootloader? What was the result?
What is the error on the 192.168.1.1 when you’re trying to log-in with admin/admin01?
