Hi
I try to setup a RUT950 device in Germany. After setting up mobile network and reboot the mobile status LED blinks some timer red-yellow-green and then lights up in green, also the signal strength led light up (three dots). On the overview page I see a successful connection and also sometime an external IP address.
But after a few seconds the connection drops and does not reconnect, even if I try to access some internet pages from a connected computer. The mobile LED lights steady red then.
On network status board under Mobile I see only empty fields. This effect often appears on other pages, too.Reboot modem button has no effect, except the button gets greyed out and you get a busy marker on the top right of the screen.
I see no warnings or errors in event log.
The overall performance of the WebUI is very slow. It often takes up to 30 seconds until the fields get filled with data.
Also I don’t see the Wifi network of the router on my mobile phone, but I can connect manually. On a desktop Windows PC the Wifi network shows up correctly.
So it seems the router has some general problems, but how to analyse it.
Firmware is RUT9XX_R_00.06.09.5
P.S.: currently I get only an empty overview page
Any help would be appreciated.
Regards
Thorsten
