Can VPN Hub users download only their own client configuration?
Hi everyone,
We’re a team of administrators using RMS VPN Hubs. Each administrator is added as an individual user client and has their own .ovpn configuration file for connecting to the hub.
Currently, any administrator can download the configuration files for all clients from the hub’s Clients tab, including other users’ files.
I found the View VPN Hub users permission under Roles. When I disable it, the Clients tab shows Forbidden, and the user can no longer download their own configuration either.
Is it possible to let each administrator view and download only their own client configuration while preventing access to the other users’ configurations? If so, how should I configure the roles or VPN Hub?
Thanks in advance!
Thank you for reaching out.
This functionality is currently unavailable in RMS. The View VPN Hub users permission applies to the entire client list and cannot be restricted to an administrator’s own configuration.
Enabling this permission allows access to all clients’ configurations, while disabling it also prevents users from downloading their own. There is currently no role or VPN Hub setting that provides this per-user access.
I will forward your suggestion for further evaluation.
T.
