Can not login to RMS after UI update
Starting from yesterday, adter latest UI update, I can not login anymore to Teltonika RMS.
When logging normaly it says “bad credentials” and when logging with SSO it gives me Server error and “Failed to connect to server”.
What is the issue there? Other colleagues inside my organization can login normally.
Thanks,
Ninoslav
I’m having similar issues, I am unable to change the associated email address. when changing the email I get a success message but then receive a confirmation email (to the new email address) and must confirm the change, but the button and link do not work (tried on multiple browsers). Teltonika seem to have issues when making changes as this is not the first time the rms has broken when changes are implemented.
Wishing you luck and hope your issues is sorted ASAP!
Our R&D team is already aware of this matter and is currently analyzing the issue.
We appreciate your patience and understanding while they work on resolving it.
