I think the topic says it all.
Regards, Martin
Luci is no longer supported with RUTOS. We are now using Vuci instead. If you downgrade to Legacy firmware, you can revert to the Luci interface. However, your device has the RUT2M_R_00.07.01.3 firmware version, so downgrading to Luci is not possible.
Thank you. What is Vuci? Can you point to a document?
Regards, M.
VUCI is a web-based graphical user interface, similar to LUCI. However, instead of using Lua, VUCI uses Vue.js. Unfortunately, there is no documentation available for clients or end users at this time.
For more information, you can check out this community forum post: How to customize the new Vue-based UI.
