I’m using the RMS API to run device actions. It is mostly working well, but I’m hitting a problem with the /devices/{id}/command endpoint.
When running certain commands, I get a Timeout response from the Status API, even though the command was successful (device ID set to 123456 in the examples below).
Example 1 — results in a Timeout
Command
curl \
--header "Authorization: Bearer {my_pat_token}" \
--header 'Content-Type: application/json' \
--data '{ "command": "mctl --reset" }' \
--url "https://rms.teltonika-networks.com/api/devices/123456/command"
Result
"success": true,
"data": {
"123456": [
"status": "pending",
"type": "text",
"value": "Sending custom command..."
"errorCode": 65545, // |
"status": "error", // APPEARS TO BE AN ERROR??
"type": "text", // |
"value": "Timeout." // |
Example 2 — “Successful”
Command
curl \
--data '{ "command": "api post /modems/3-1/actions/reboot" }' \
Result
"success": true,
"data": {
"123456": [
"type": "text",
"status": "completed",
"type": "text",
"value": "{\"http_body\":{\"success\":true},\"http_code\":200}\n"
I have tried running the first command as mctl --reset & to tell the shell not to wait for it to complete, but it does not help.
Is this a bug with the API, or am I somehow calling it incorrectly?
