I would like to import some RUT 951 on RMS, but I can’t find how to collect the management password without typing it by hand. The QR code on the router doesn’t work and on the box doesn’t display the management password. Do you have any solutions ?
For older devices, there’s not much that can be done. The suggestion is to collect and enter the passwords manually.
If you have many RUT devices, I would recommend adding the devices to RMS from a file. Basically, you can put the device information into a CSV file and upload it. You can find more information here.
When purchasing the devices from Teltonika Networks, you have the option to request a file with device passwords. However, Teltonika Networks does not hold device passwords for long, so if you purchased your them more than a month ago, it is likely that Teltonika no longer has passwords for them.
