Hi @flebourse ,
Thanks for the fast response.
I built the project but unfortunately I cannot Upload the whole file (I am a new user in the forum).It seems that this build has a different output.
Below I upload some of the last lines:
rm -f libexfat.a
mips-openwrt-linux-musl-gcc-ar cru libexfat.a libexfat.o
/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/lib/gcc/mips-openwrt-linux-musl/8.4.0/../../../../mips-openwrt-linux-musl/bin/ar: `u' modifier ignored since `D' is the default (see `U')
mips-openwrt-linux-musl-gcc-ranlib libexfat.a
make[6]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/lib'
Making all in mkfs
make[6]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/mkfs'
depbase=`echo mkfs.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
mips-openwrt-linux-musl-gcc -DHAVE_CONFIG_H -I. -I.. -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/include -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include/fortify -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include -DRUT9_PLATFORM -DMOBILE_SUPPORT -DDUAL_SIM_SUPPORT -DGPS_SUPPORT -DWIFI_SUPPORT -DIO_SUPPORT -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -MT mkfs.o -MD -MP -MF $depbase.Tpo -c -o mkfs.o mkfs.c &&\
mv -f $depbase.Tpo $depbase.Po
depbase=`echo upcase.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
mips-openwrt-linux-musl-gcc -DHAVE_CONFIG_H -I. -I.. -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/include -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include/fortify -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include -DRUT9_PLATFORM -DMOBILE_SUPPORT -DDUAL_SIM_SUPPORT -DGPS_SUPPORT -DWIFI_SUPPORT -DIO_SUPPORT -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -MT upcase.o -MD -MP -MF $depbase.Tpo -c -o upcase.o upcase.c &&\
/bin/bash ../libtool --tag=CC --mode=link mips-openwrt-linux-musl-gcc -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/lib -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/lib -znow -zrelro -o mkfs.exfat mkfs.o upcase.o ../lib/libexfat.a
OpenWrt-libtool: link: mips-openwrt-linux-musl-gcc -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z -Wl,now -Wl,-z -Wl,relro -znow -zrelro -o mkfs.exfat mkfs.o upcase.o -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/lib -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/lib ../lib/libexfat.a
make[6]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/mkfs'
Making all in fsck
make[6]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/fsck'
depbase=`echo fsck.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
mips-openwrt-linux-musl-gcc -DHAVE_CONFIG_H -I. -I.. -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/include -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include/fortify -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include -DRUT9_PLATFORM -DMOBILE_SUPPORT -DDUAL_SIM_SUPPORT -DGPS_SUPPORT -DWIFI_SUPPORT -DIO_SUPPORT -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -MT fsck.o -MD -MP -MF $depbase.Tpo -c -o fsck.o fsck.c &&\
depbase=`echo repair.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
mips-openwrt-linux-musl-gcc -DHAVE_CONFIG_H -I. -I.. -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/include -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include/fortify -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include -DRUT9_PLATFORM -DMOBILE_SUPPORT -DDUAL_SIM_SUPPORT -DGPS_SUPPORT -DWIFI_SUPPORT -DIO_SUPPORT -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -MT repair.o -MD -MP -MF $depbase.Tpo -c -o repair.o repair.c &&\
depbase=`echo de_iter.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
mips-openwrt-linux-musl-gcc -DHAVE_CONFIG_H -I. -I.. -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/include -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include/fortify -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include -DRUT9_PLATFORM -DMOBILE_SUPPORT -DDUAL_SIM_SUPPORT -DGPS_SUPPORT -DWIFI_SUPPORT -DIO_SUPPORT -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -MT de_iter.o -MD -MP -MF $depbase.Tpo -c -o de_iter.o de_iter.c &&\
/bin/bash ../libtool --tag=CC --mode=link mips-openwrt-linux-musl-gcc -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/lib -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/lib -znow -zrelro -o fsck.exfat fsck.o repair.o de_iter.o ../lib/libexfat.a
OpenWrt-libtool: link: mips-openwrt-linux-musl-gcc -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z -Wl,now -Wl,-z -Wl,relro -znow -zrelro -o fsck.exfat fsck.o repair.o de_iter.o -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/lib -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/lib ../lib/libexfat.a
make[6]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/fsck'
Making all in tune
make[6]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/tune'
depbase=`echo tune.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
mips-openwrt-linux-musl-gcc -DHAVE_CONFIG_H -I. -I.. -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/include -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include/fortify -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include -DRUT9_PLATFORM -DMOBILE_SUPPORT -DDUAL_SIM_SUPPORT -DGPS_SUPPORT -DWIFI_SUPPORT -DIO_SUPPORT -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -MT tune.o -MD -MP -MF $depbase.Tpo -c -o tune.o tune.c &&\
/bin/bash ../libtool --tag=CC --mode=link mips-openwrt-linux-musl-gcc -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/lib -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/lib -znow -zrelro -o tune.exfat tune.o ../lib/libexfat.a
OpenWrt-libtool: link: mips-openwrt-linux-musl-gcc -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z -Wl,now -Wl,-z -Wl,relro -znow -zrelro -o tune.exfat tune.o -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/lib -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/lib ../lib/libexfat.a
make[6]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/tune'
Making all in label
make[6]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/label'
depbase=`echo label.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
mips-openwrt-linux-musl-gcc -DHAVE_CONFIG_H -I. -I.. -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/include -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include/fortify -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include -DRUT9_PLATFORM -DMOBILE_SUPPORT -DDUAL_SIM_SUPPORT -DGPS_SUPPORT -DWIFI_SUPPORT -DIO_SUPPORT -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -MT label.o -MD -MP -MF $depbase.Tpo -c -o label.o label.c &&\
/bin/bash ../libtool --tag=CC --mode=link mips-openwrt-linux-musl-gcc -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/lib -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/lib -znow -zrelro -o exfatlabel label.o ../lib/libexfat.a
OpenWrt-libtool: link: mips-openwrt-linux-musl-gcc -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z -Wl,now -Wl,-z -Wl,relro -znow -zrelro -o exfatlabel label.o -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/lib -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/lib ../lib/libexfat.a
make[6]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/label'
Making all in dump
make[6]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/dump'
depbase=`echo dump.o | sed 's|[^/]*$|.deps/&|;s|\.o$||'`;\
mips-openwrt-linux-musl-gcc -DHAVE_CONFIG_H -I. -I.. -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/include -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include/fortify -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include -DRUT9_PLATFORM -DMOBILE_SUPPORT -DDUAL_SIM_SUPPORT -DGPS_SUPPORT -DWIFI_SUPPORT -DIO_SUPPORT -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -MT dump.o -MD -MP -MF $depbase.Tpo -c -o dump.o dump.c &&\
/bin/bash ../libtool --tag=CC --mode=link mips-openwrt-linux-musl-gcc -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/lib -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/lib -znow -zrelro -o dump.exfat dump.o ../lib/libexfat.a
OpenWrt-libtool: link: mips-openwrt-linux-musl-gcc -Wall -include ../config.h -I../include -fno-common -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z -Wl,now -Wl,-z -Wl,relro -znow -zrelro -o dump.exfat dump.o -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/lib -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/lib ../lib/libexfat.a
make[6]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/dump'
make[6]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3'
make[6]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3'
make[5]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3'
make[4]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3'
CFLAGS="-Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/include -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include/fortify -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include -DRUT9_PLATFORM -DMOBILE_SUPPORT -DDUAL_SIM_SUPPORT -DGPS_SUPPORT -DWIFI_SUPPORT -DIO_SUPPORT " CXXFLAGS="-Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -mips16 -minterlink-mips16 -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/include -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include/fortify -I/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/include -DRUT9_PLATFORM -DMOBILE_SUPPORT -DDUAL_SIM_SUPPORT -DGPS_SUPPORT -DWIFI_SUPPORT -DIO_SUPPORT " LDFLAGS="-L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/usr/lib -L/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/toolchain-mips_74kc_gcc-8.4.0_musl/lib -znow -zrelro " make -C /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/. AR="mips-openwrt-linux-musl-gcc-ar" AS="mips-openwrt-linux-musl-gcc -c -Os -pipe -mno-branch-likely -mips32r2 -mtune=74kc -fno-caller-saves -fno-plt -fhonour-copts -Wno-error=unused-but-set-variable -Wno-error=unused-result -msoft-float -fmacro-prefix-map=/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3=exfatprogs-1.1.3 -Wformat -Werror=format-security -fstack-protector -D_FORTIFY_SOURCE=1 -Wl,-z,now -Wl,-z,relro" LD=mips-openwrt-linux-musl-ld NM="mips-openwrt-linux-musl-gcc-nm" CC="mips-openwrt-linux-musl-gcc" GCOV="mips-openwrt-linux-musl-gcc" GCC="mips-openwrt-linux-musl-gcc" CXX="mips-openwrt-linux-musl-g++" RANLIB="mips-openwrt-linux-musl-gcc-ranlib" STRIP=mips-openwrt-linux-musl-strip OBJCOPY=mips-openwrt-linux-musl-objcopy OBJDUMP=mips-openwrt-linux-musl-objdump SIZE=mips-openwrt-linux-musl-size CROSS="mips-openwrt-linux-musl-" ARCH="mips" DESTDIR="/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install" install;
make[4]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3'
Making install in lib
make[5]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/lib'
make[6]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/lib'
make[6]: Nothing to be done for 'install-exec-am'.
make[6]: Nothing to be done for 'install-data-am'.
make[5]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/lib'
Making install in mkfs
make[5]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/mkfs'
/usr/bin/mkdir -p '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/sbin'
/bin/bash ../libtool --mode=install /usr/bin/install -c mkfs.exfat '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/sbin'
OpenWrt-libtool: install: /usr/bin/install -c mkfs.exfat /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/sbin/mkfs.exfat
make[5]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/mkfs'
Making install in fsck
make[5]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/fsck'
/bin/bash ../libtool --mode=install /usr/bin/install -c fsck.exfat '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/sbin'
OpenWrt-libtool: install: /usr/bin/install -c fsck.exfat /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/sbin/fsck.exfat
make[5]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/fsck'
Making install in tune
make[5]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/tune'
/bin/bash ../libtool --mode=install /usr/bin/install -c tune.exfat '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/sbin'
OpenWrt-libtool: install: /usr/bin/install -c tune.exfat /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/sbin/tune.exfat
make[5]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/tune'
Making install in label
make[5]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/label'
/bin/bash ../libtool --mode=install /usr/bin/install -c exfatlabel '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/sbin'
OpenWrt-libtool: install: /usr/bin/install -c exfatlabel /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/sbin/exfatlabel
make[5]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/label'
Making install in dump
make[5]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/dump'
/bin/bash ../libtool --mode=install /usr/bin/install -c dump.exfat '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/sbin'
OpenWrt-libtool: install: /usr/bin/install -c dump.exfat /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/sbin/dump.exfat
make[5]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/dump'
make[5]: Entering directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3'
/usr/bin/mkdir -p '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/man/man8'
/usr/bin/install -c -m 644 manpages/fsck.exfat.8 manpages/tune.exfat.8 manpages/mkfs.exfat.8 manpages/exfatlabel.8 manpages/dump.exfat.8 '/home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/man/man8'
touch /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/.built
rm -rf /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/.pkgdir/exfat-mkfs.installed /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/.pkgdir/exfat-mkfs
mkdir -p /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/.pkgdir/exfat-mkfs
install -d -m0755 /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/.pkgdir/exfat-mkfs/usr/sbin
install -m0755 /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/sbin/mkfs.exfat /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/.pkgdir/exfat-mkfs/usr/sbin
touch /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/.pkgdir/exfat-mkfs.installed
mkdir -p /home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/target-mips_74kc_musl/root-ath79/stamp
SHELL= flock /home/kontogiorgis/rutos-ath79-rut9-gpl/tmp/.root-copy.flock -c 'cp -fpR /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/.pkgdir/exfat-mkfs/. /home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/target-mips_74kc_musl/root-ath79/'
touch /home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/target-mips_74kc_musl/root-ath79/stamp/.exfat-mkfs_installed
mkdir -p /home/kontogiorgis/rutos-ath79-rut9-gpl/bin/targets/ath79/74kc/packages /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-mips_24kc/exfat-mkfs/CONTROL /home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/target-mips_74kc_musl/pkginfo
install -d -m0755 /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-mips_24kc/exfat-mkfs/usr/sbin
install -m0755 /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-install/usr/sbin/mkfs.exfat /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-mips_24kc/exfat-mkfs/usr/sbin
find /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-mips_24kc/exfat-mkfs -name 'CVS' -o -name '.svn' -o -name '.#*' -o -name '*~'| xargs -r rm -rf
export CROSS="mips-openwrt-linux-musl-" ; NM="mips-openwrt-linux-musl-nm" STRIP="/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/host/bin/sstrip -z" STRIP_KMOD="/home/kontogiorgis/rutos-ath79-rut9-gpl/scripts/strip-kmod.sh" PATCHELF="/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/host/bin/patchelf" /home/kontogiorgis/rutos-ath79-rut9-gpl/scripts/rstrip.sh /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-mips_24kc/exfat-mkfs
rstrip.sh: /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-mips_24kc/exfat-mkfs/usr/sbin/mkfs.exfat: executable
(cd /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-mips_24kc/exfat-mkfs/CONTROL; ( echo "$CONTROL"; printf "Description: "; echo "$DESCRIPTION" | sed -e 's,^[[:space:]]*, ,g'; ) > control; chmod 644 control; ( echo "#!/bin/sh"; echo "[ \"\${IPKG_NO_SCRIPT}\" = \"1\" ] && exit 0"; echo "[ -s "\${IPKG_INSTROOT}/lib/functions.sh" ] || exit 0"; echo ". \${IPKG_INSTROOT}/lib/functions.sh"; echo "default_postinst \$0 \$@"; ) > postinst; ( echo "#!/bin/sh"; echo "[ -s "\${IPKG_INSTROOT}/lib/functions.sh" ] || exit 0"; echo ". \${IPKG_INSTROOT}/lib/functions.sh"; echo "default_prerm \$0 \$@"; ) > prerm; chmod 0755 postinst prerm; )
install -d -m0755 /home/kontogiorgis/rutos-ath79-rut9-gpl/bin/packages/mips_24kc/base
/home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/host/bin/fakeroot /home/kontogiorgis/rutos-ath79-rut9-gpl/scripts/ipkg-build -m "" /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-mips_24kc/exfat-mkfs /home/kontogiorgis/rutos-ath79-rut9-gpl/bin/packages/mips_24kc/base
Packaged contents of /home/kontogiorgis/rutos-ath79-rut9-gpl/build_dir/target-mips_74kc_musl/exfatprogs-1.1.3/ipkg-mips_24kc/exfat-mkfs into /home/kontogiorgis/rutos-ath79-rut9-gpl/bin/packages/mips_24kc/base/exfat-mkfs_1.1.3-240112.41471_mips_24kc.ipk
echo "exfat-mkfs" >> /home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/target-mips_74kc_musl/pkginfo/exfatprogs.default.install
make[3]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl/package/utils/exfatprogs'
time: package/utils/exfatprogs/compile#6.80#1.32#9.08
make[2]: Target 'package/compile' not remade because of errors.
make[2]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl'
make[1]: *** [package/Makefile:108: /home/kontogiorgis/rutos-ath79-rut9-gpl/staging_dir/target-mips_74kc_musl/stamp/.package_compile] Error 2
make[1]: Target 'world' not remade because of errors.
make[1]: Leaving directory '/home/kontogiorgis/rutos-ath79-rut9-gpl'
make: *** [/home/kontogiorgis/rutos-ath79-rut9-gpl/include/toplevel.mk:238: world] Error 2
