Bug report RUT241
Hereby I want to report a minor bug in the RUT241.
I am using Data to Server to send 4x Modbus values to MQTT.
Every time I go into Data Configuration the Request Name is set back to one name.
Then I need to add the other three names, otherwise it jumps back to only send one value.
All 4 request names (or how many you have added) should be displayed when you enter the Data Configuration screen again.
As said it is a minor issue, but when you are not aware it could be frustrating why you only see one value and think there is something wrong.
Thank you for reaching out.
Could you please confirm the firmware version installed on your RUT241? If it’s an older version, I recommend updating it to the latest 7.11.2 firmware to ensure optimal functionality.
If I understand correctly, you have configured 4 Modbus data inputs in your Data to Server collection. In such cases, only one Modbus data input is needed for proper functionality, and you don’t need to configure them separately.
To help investigate further, it would be ideal if you could provide screenshots of the following:
  1. Data to Server data configuration window.
  2. Modbus TCP Client Requests configuration.
