Bug Report: Firmware file upgrade ignored sysupgrade.conf
RUTX50 Firmware: RUTX_R_00.07.08 tried to upgrade firmware to RUTX_R_00.07.08.1 using server download which failed silently. Downloaded the bin file RUTX_R_00.07.08.1_WEBUI.bin from wiki.teltonika-networks.com/view/RUTX50_Firmware_Downloads and performed a file upgrade from the admin interface which succeeded. However, in the process (or possibly, but unlikely the modem upgrade which immediately preceeded) a directory listed in sysupgrade.conf was deleted.
Expected behaviour:
Directory should have been preserved during upgrade.
Just to add that I have done two previous firmware upgrades using the server method from the admin interface and they worked as expected.
Hi Falstone,
This firmware version was removed due to an issue with FOTA firmware download. Can you upgrade to 7.08.2 and let me know if files and directories are preserved by sysupgrade.conf?
Hope this helps.
