Blink Smart Cameras
Hello, I’m having a problem trying to connect a blink camera system to my Teltonika RUTX11 LTE Router. Blink uses a sync module that connects to WiFi. It simply won’t complete the connection process. Is there some kind of firewall preventing the connection. I’ve done a factory reset of the router and still the same issue. I’ve also tried to connect a different smart camera system and I still have problems. Anyone else had any similar issues?
If you can connect with your mobile or laptop, via WiFi on a 2.4GHz channel, using WPA or WPA2-PSK, then I suggest you direct your question to Blink Support.
