I have a DMVPN setup with IPSEC and BGP. The problem is that the default route from BGP is not installed in the routing table so i have to set a static route. This works but is not a permanent solution if the Teltonika is for example not the last router in a redundancy setup.
This is the route received by BGP:
I need to disable something like this but for the mobile interface i guess:
This is (part of) the routing table:
I have seen several similar topics but i haven’t been able to solve this.
