Before fixing Failover's health check, enabling an unused WiFi WAN interface (wifi1) made my VPN connect. Why?
PROBLEM
Failover marked my working eSIM interface (mobile_esim2) Offline while LAN clients browsed normally. Proton VPN could not connect in that state. Enabling a WiFi WAN interface (wifi1) in Failover made the VPN connect, even though wifi1 had no link and mobile_esim2 still showed Offline. I solved the real problem, but I don’t understand why having a useless wifi1 interface changed the behavior.
ENVIRONMENT
RUTX50 (eSIM variant), RUTX_R_00.07.26.2, Failover mode (not load balancing).
  • mobile_esim2: SIM 3 (eSIM2), APN Auto, has an IP and carries traffic.
  • wifi1: WiFi client WAN (DHCP client, wan zone), no SSID or network interface on it.
STEPS TO REPRODUCE
  1. Enable only mobile_esim2 in Failover. Method Ping, Track IP 9.9.9.9 and 149.112.112.112. The General page shows it Offline, 0% traffic, both targets (down). I guess those IPs from q9 were down.
  2. Proton VPN (Smart Protocol, so it tried every protocol it supports) fails to connect.
  3. Enable the dummy wifi1 in Failover. The VPN connects. Disable it and the VPN fails. I repeated this with the same result. Enabling mobile_esim1 and sim1 made no difference.
SOLUTION TO MAKE PROTON VPN CONNECT
Change mobile_esim2’s health check Method to Wget with http://neverssl.com and http://wikipedia.org. Failover shows it Online and the VPN connects with wifi1 disabled. I no longer need wifi1.
QUESTION
Why did enabling wifi1 change the VPN’s behavior while mobile_esim2 was Offline? What does Failover or mwan3 do with new connections when no member is Online, and does an extra member change that? If there is a page or log that shows it, I can attach screenshots.
Thank you for reaching out. To understand why enabling wifi1 allowed Proton VPN to connect, we’d like to compare the router’s failover status during both attempts.
You can open the router’s command line in either of these ways:
  • From a browser: Sign in to the router’s WebUI and go to System → Maintenance → CLI. Log in as root using your WebUI admin password.
  • From a Windows PC: Open PowerShell and run ssh root@192.168.1.1, replacing the IP address with your router’s LAN address. Enter your WebUI admin password when prompted.
When convenient, please restore the original Ping health check and wait until mobile_esim2 shows Offline. Try connecting to Proton VPN first with wifi1 disabled, then start a fresh connection with wifi1 enabled. Keep the ping settings the same for both tests.
For both attempts, please run mwan3 status after the connection attempt and send us the output or a screenshot.
Please remove or blur any private information.
T.
