BAT120 achieving less than an hour backup
Hi Teltonika Support,
I’ve been using a Teltonika BAT120 UPS alongside a RUTX50 router. According to Teltonika’s documentation, the BAT120 should keep a compatible device running for up to 6 hours - but I’m seeing less than 1 hour of backup.
Here’s what I did:
  • Fully charged the BAT120 (all 4 LEDs lit).
  • Disconnected input power to test uninterrupted mode.
  • Less than an hour in, the BAT120 shut down.
  • When I reconnected power, it started charging again, showing 3 LEDs.
This seems off, especially considering the unit is only about a year old. I’ve captured some videos of the behavior in case that helps with diagnostics. Any advice or support would be appreciated.
Thanks!
The device losing its charge so fast in a year sounds like a hardware-related issue. I would suggest reaching out to the shop/distributor that the device was purchased from, provide them with the serial number & ask for a repair/replacement.
Hi M,
I’ve contacted the distributor, and they confirmed they will follow up with you directly. Given Teltonika’s marketing for such devices in terms of reliability and robustness, looking forward to a resolution.
Many thanks.
