Bandwidth Problems on RUT241 and OPENVPN
Hello, I had set up a RUT241 with an OPENVPN connection. So now if I do a speediest I only get ~5mbit/sec and the CPU load is constant at 100%. My FW version is 7.12.3. So my question is, is this a common and known problem? Is this a hardware limitation of the encryption speed of the CPU?
Sidenote: If i switch off the OPENVPN connection I got at least 100mbit/sec so it is not a general bandwidth problem.
Hi…
RUT200 don’t have a hardware to handle the ovpn criptografy, so… CPU need to do the job.
Also… the cpu do everything… WiFi, route, RutOS, etc…
This is the reason to have a limited throughput when using ovpn or any vpn that needs criptografy.
Some IT guys are using wireguard, because is a light vpn and works better in a small network devices.
Hello @Jan1,
Could you please confirm whether your issue has been resolved, or if you still require assistance?
