I cant access the web ui. I tried reboot from button but it doesnt work .HELP PLEASE
Hello Billargi,
Here are a few key points to check:
- Could you check what is the LAN IP address of your computer in CMD by entering
ifconfig
command? - Additionally, can you ping the router’s default IP 192.168.1.1 from the PC by executing
ping 192.168.1.1
- Reset the router to default settings by pressing and holding the reset button for at least 12 seconds.
- Try to reinstall the router’s firmware via the bootloader’s menu. For this follow the guidelines provided in the article here.
Let me know if anything helps or if you need further assistance.
