Spoken to Justin.
Issue with trying to get BACnet router working with a IPSEC tunnel on a RUT976.
IPSEC tunnel is configured with remote subnet 172.28.64.65/26 and local 10.100.93/024 rut is 10.100.93.1.
Remote subnet device 172.28.64.125 can ping the rut LAN IP through the IPSEC tunnel and the rut can ping the remote device.
BACnet configuration:
BBMD enabled
BBMD interface = qmimux
BIP configuration:
Network ID 9310
Interface = eth0.1
MSTP enabled on RS485 port
With this setup I can connect to the MSTP device through the rut when locally connected. When I attempt to register with the BBMD from the remote device I get a response
BBMD Message Received(6): addr=10.100.93.1, port=47809
BBMD<<< BVLC-Result received: resultCode=0
but it is not forwarding messages because when I do a Who-is from the remote device I get no response.
I have tried changing the interface on the BBMD and BIP and no matter what I do it does not work. (The firmware does not allow the BBMD and BIP to bound to the same interface) If its moved from qmimux then it stops responding to registrations.
Please can you advise.
