We are experiencing an issue with BACnet/IP communication between two remote sites connected via Teltonika RMS VPN.
The topology is as follows (the diagram is attached as well):
-Two Teltonika OTD140 devices (Hotel & Pumpstation)
-Both devices are connected to the same RMS VPN hub
-Each device has a local BACnet/IP subnet:
-Hotel side: 192.168.197.0/24
-Pumpstation side: 192.168.198.0/24
-Devices behind routers:
-Hotel controller: 192.168.197.10 (not BBMD)
-Pumpstation controller: 192.168.198.10 (BBMD enabled)
- Pumpstation controller (192.168.198.10) is configured as BBMD.
Its BDT includes:
- 192.168.198.10/32 :47808
- 192.168.198.1/32 :47808
- 192.168.197.1/32 :47808
The hotel’s side has no BBMD-capable controller, so we want to configure OTD140 (Hotel) as BBMD for the subnet 192.168.197.0/24. The main difference with the Pumpstation side is that Hotel’s OTD-140 is connected to the WAN port of the Siemens controller!!
Issue:
Although:
- IP connectivity between subnets is working (ping OK)
- UDP 47808 is allowed in firewall.
- BACnet traffic is visible locally on both sides.
We observe that:
- BACnet broadcast traffic from 192.168.197.10 remains local (does not get forwarded correctly).
- When BBMD is configured on the Hotel OTD140 using LAN interface (
br-lan/eth0.1), forwarding does not occur. - When BBMD interface is set to WAN (
usb0), traffic is forwarded, but communication still fails (likely due to incorrect BBMD identity/source IP)
-BBMD messages stay unconfirmed every time.
As a result:
- The two controllers (192.168.197.10 and 192.168.198.10) cannot communicate.
- The Pumpstation controller still reports ‘‘communication failure’’.
–What we need clarification on
We would like to understand:
- Is BBMD over RMS VPN fully supported on OTD140 devices?
- Is there any limitation when binding BBMD to LAN interfaces while routing over VPN?
- What is the correct design when:
-One side uses a controller as BBMD.
-The other side uses the Teltonika device as BBMD. - Should BBMD traffic be bound to LAN or WAN interface when using RMS VPN?
- What happens with BDT and BIP configuration?
- Are there known issues with BBMD forwarding through VPN interfaces (tun)?
Thank you in advance,
Manos Anastasiou
